| Yes as stated before, I did this because MDF is not always 1/2" wide depends on where the outlet gets their material from, if you want you can change it back to 1/2" but i did run into this problem getting material from lowes and Homedepot, even between different Homedepot stores themselves. In a perfect world it would work but we do not live in a perfect world. Joe |
| Sheet goods (including MDF) plywood, chipboard, depending on supplier can vary as much as a 1/16" of an inch less and sometimes a hair over. You should get your material and mic a sheet and make the adjustments necessary before cutting everything. |
| With Gorilla glue, you don't really want a gap. The expanded foam is actually very weak. You can have much tighter joints than with regular wood glue, because the Gorilla glue acts like a lubricant and tight joints will slide together easily.
I second that, titebond is the best, I never understand the need for gorilla glue at all, I do woodwork every day and have never seen the need for it. |
| ACAD formula help please | ImanCarrot | Autodesk Software (Autocad, Inventor etc) | 1 | 04-06-2011 08:51 PM |
| Acad 07 to mastercamX | Demon440 | Mastercam | 3 | 01-04-2007 09:04 AM |
| Help with selector switch wiring issue (***actually a motor issue***) | BEDFORD | Industrial Hobbies (Support forum) | 7 | 04-07-2006 03:19 PM |
| how do i get my cnc to cut my acad dwg? | ljoe1969 | Autodesk Software (Autocad, Inventor etc) | 6 | 11-05-2003 10:05 AM |
| ACAD 2002 issues???? | DanFri | Autodesk Software (Autocad, Inventor etc) | 4 | 07-02-2003 01:16 PM |
