NAPA auto parts #733-5408 5/16 x 2" exhaust clamp. Haven't used them yet in the z assembly, but they have the right span. Not sure if they are long enough yet, but will let you know tomorrow. |
| Actually guys, I've found that the 5/16" X 1.5" work great. I had a heck of time bending the 2" U bolts and I think it was a happy accident that the 1.5" fit without any fighting. In my particular case, the 2" bolts put some much strain on the Z bearing assembly that it cracked on one corner. I had to recut the bearing plate assembly and I am now using the 1.5" bolts and it seems to be working great with no other modification. Just my observation....... Joe |
| Good info, I know by getting bolts from different sources, you an had a sligh variation in actual length between bolts, so it is always good to measure before you buy, but if you get them online you have to just see how it works when you get them. Joe |
| Have you had problems that require power-on reset? | gar | Haas Mills | 21 | 03-09-2012 07:54 AM |
| Require material which laser can't cut | Kiwi | Laser Engraving & Cutting Machines | 17 | 01-12-2008 12:09 AM |
| card require of siemens control | rajesh_1355 | Fanuc | 0 | 07-01-2007 01:10 PM |
| Eccentric bolts | JerryFlyGuy | Mechanical Calculations/Engineering Design | 14 | 01-17-2007 10:01 PM |
| HSR rail bolts? | Gnu | Linear and Rotary Motion | 8 | 01-10-2007 04:24 PM |
