| I am collecting all the hardware for a modified Joe 2006. I have the R8ZZ 1/2"x1 1/8"x5/16" bearings and today received my 1018 Carbon Steel Precision Acme Threaded Rod 1/2"-8 Acme Size, 4 Turns/Inch, 6'L, Rh Thread from McMaster Carr part #99030A716 The bearings will not go on the rods! I have the Dumbstercnc parts on the way, I just saw on there website that they are for McMaster Carr Acme Threaded Rod part #98940A629 I did not see any differnce in the two Acme Threaded Rod part numbers other than that they are made from differnt metals. Am I going to have a problem with this, or is there a way to make all this work? |
| travisc, others have seen the same. Most have turned down the screw slightly with a lathe setup and a file. Some have made a homemade lathe ( just a drill to turn the rod) and a file to remove a small amount of material. I have the same materials and plan to do the same. I have a wood lathe, and will use it to turn the rod so I can file off enough to fit the bearings. I haven't measured mine yet, but I believe reported oversize is about .003 |
| It looks like you bought 1/2-8 screws and nuts for 1/2-10 . Are you sure you have those nuts, because they won't work. ![]() As for the bearings, try spinning the screw in a drill, and lightly filing or sanding it until they slide on.
| Thanks, BobF I will make a lathe setup and fix the screws Ger21 I copied and pasted the wrong part number in my post, it should have been 98940A623, for the nuts that matches the 1/2"-8 ACME 2 Start so, I did order the correct one. |
| yup, i had the same problem, i posted a picture of my simple jig with a drill as shown in the Mod section Post #32 Joe's CNC Model 2006 (Mods & Additions) Joe |
| I did what joe did as well, it's a common problem. Once you sand it down consistently (or file it) the threads will be a little off. I found after jogging the machine around a bit it will work those threads back into place well and it will be smooth riding again. |
| Tight linear bearings | pixpop | Linear and Rotary Motion | 14 | 10-04-2007 05:40 AM |
| Tapered roller bearing vs. angular contact bearing | boyvox | Linear and Rotary Motion | 12 | 01-25-2007 03:49 PM |
| HIWIN linear guide too tight | IQChallenged | Linear and Rotary Motion | 4 | 12-21-2006 03:19 PM |
| R8 Collet will not hold tight! | bgolash | General Metalwork Discussion | 9 | 03-23-2006 04:30 PM |
| Tight lead screws | MrWild | Linear and Rotary Motion | 1 | 11-24-2005 03:32 PM |
