Joe
Absolutely no offence taken. I could see how it looked odd that my pals showed up like that.
You are one of my heroes along with Art.
It does not make my candle burn any brighter to blow someone else’s out.
The Mach3 program is a wonderful program. As a whole machine motion is indeed very impressive. From my point of view Art with his Mach3 program has done a wonderful job of plowing the field for me.
You are right about how crappy my web page was a few years ago. It’s still not up to snuff if you ask me.
And the SuperCam user interface at first looks DOS clunky. And it certainly does not appear to have much to do with machine control, as you would expect it to.
A couple of years ago I was in manic mode being an asocial programmer. I was half on and half off the horse and it was moving. No excuses, just the way it was.
But that was then, the mission did get completed. I invite you to take another look at SuperCamXp.
As a matter of fact there is a screen shot of one of your drawings on the cover of the Users Guide for SuperCamXp. If that gives you any angst just let me know I’ll put something else there.
Your DXF files almost import perfectly into SuperCamXp, some of the text comes in the wrong size and orientation. That’s one of the things I need to work on. But as a whole they are good to go and you could make parts straight away with them. Having points in the middle of the drill holes would make them perfect.
I would be happy to send you a USB CamPod and SuperCamXp, just give it a whirl. I am certain you will find it a real treat to run one of your machines with it.
Sincerely
Dennis
http://www.super-tech.com
