| V Carve Hi Everyone: I have seen that many of you are using Vcarve. I downloaded the Demo and have been playing with it. I'm confused about the need to use "Stepover" when programming a "Profile" tool path. In my current CAM program it's called "Contour" and all I do is plunge 50% of my Cutter Diameter until I'm through the material. Like 4 cuts of .125 for a .5 piece of "Baltic Birch". All the tool does is descend .125 for 4 consecutive passes. With VCarve I have to enter a "Stepover" value for the same operation. Now if I were to do a "Pocket" I would need "Stepover". I think that this means that the 2nd pass moves in the "XY" plane by the "Stepover" amount as well as plunging the programmed "Z", and so on. Since I can program this "Stepover" to .0001, I suppose it's Academic, but the question is "Why" is this necessary?? Any imput on this subject is appreciated, Thanks very much, John |
| Profile toolpaths don't have "stepover"? Unless your talking about in the tool files. But it's not used for profile toolpaths. At least not in Version 4 that I have.
| I believe you set the stepover in the bit definition. Vcarve decides if it is needed on a given cut.
__________________ In the words of the Toolman--If you didn't make it yourself, it's not really yours! Remember- done beats perfect every time!! |
The Stepover is not used (thanks Gerry and Dave) when cutting with any of the Profile Machining options - the toolpaths are simply offset for the tool radius / shape. You need to Edit the Pass Depth to create multiple Z level passes - using your example of cutting through 1/2" material with a Pass Depth = 0.125 " will result in 4 passes. The Stepover parameter is visible in the Tool Database because any of the cutters may be used for Profile, Pocketing, Engraving etc. I hope this makes sense and helps, Tony |
| VCarve Thanks Tony: That answers the question. I tried to find that information somewhere in the Tutorials, but was unable. It didn't make sense to use "Stepover" in Profiling mode, but I was confused because it demands that you enter one, when selecting a tool. Thanks again John |
| Help using v-carve trial | nydheart | Vectric | 12 | 04-02-2007 12:46 PM |
| V Carve PRO demo | craigy85 | Commercial CNC Wood Routers | 3 | 10-13-2006 04:43 PM |
| V Carve possible changes | Brian P | Vectric | 2 | 09-11-2006 04:32 PM |
| ImageCarve and V-Carve... | jdbaker | General CNC (Mill and Lathe) Control Software (NC) | 3 | 01-08-2006 11:09 AM |
| V-Carve...... I'm impressed | ynneb | Vectric | 0 | 01-05-2006 09:34 PM |
