Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > Joes CNC Model 2006
Old 10-16-2007, 11:08 AM
pksdms is on a distinguished road
Can these stepper be used?
Hi All,
I have 3 old xerox Sanyo Denki motors I think two are 140 or 170 and other is 180 OzIn.
I would be doing microstepping most of times, no full throttle. What do you say can these be used with Joe's model? Or I have to reduce size of Joe's say 4'x4' or 3'X1.5'?
Other question I can't get 1/2" screw for such length of X Axis, I wonder if 3/4" or 1" with 8TPI can be used with these steppers?
Plz help
P.K.
Last edited by pksdms; 10-16-2007 at 11:10 AM. Reason: OOPS - wrong place for such question, mod please move it
Old 10-16-2007, 12:23 PM
joecnc2006's Avatar
www.joescnc.com
joecnc2006 is on a distinguished road
Originally Posted by pksdms View Post
Hi All,
Plz help
P.K.
I would not recomend anything less than 200oz/in motors, (thats what i used for a year) and if you step up to 3/4 to 1" leadscrews (way overkill) you will need even more powerful motors to turn the larger mass.
Joe
Old 10-16-2007, 09:14 PM
Thanks Joe,
Why should motors of same strength be used with each Axis, although cutting strenght required with each Axis is same but length travelled is different in each Axis. Should not be X Axis Stepper more powerful?
P.K.
Wanted DIY stepper driver circuit for 6 wire stepper motors Colin300 Australia, New Zealand Club house 5 09-20-2007 10:20 PM
STEPPER DRIVER FAQ {Stepper/driver amp per phase match. huios Stepper Motors and Drives 0 08-27-2006 09:43 AM
difference between a stepper indexer and a stepper drive pcroxford Stepper Motors and Drives 0 11-02-2005 08:35 AM
