Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > Joes CNC Model 2006
Old 09-26-2007, 10:50 AM
bearwen is on a distinguished road
1/4" MDF Alternative?
Hello All,
I have a question for you guys I have not been able to find 1/4" Mdf locally but I did find a place that has 1/4" masonite(peg board with out theholes) if I am not mistaken this stuff is a lot like mdf is it not? Does anyone see any reason I cant use this on the Joe2006 instead of 1/4" MDF?
Bearwen
Old 09-26-2007, 12:45 PM
d11rdozer is on a distinguished road
Hi Bearwen
Masonite is HDF (High density fiber), is is a lot harder than MDF. Not familiar with Joe´s design but in principle it shoud work as an alternative
Regards
Braam
Old 09-26-2007, 01:01 PM
gacrwell is on a distinguished road
I was recently hunting for 1/4 MDF, and what I found at Home Depot wasn't in the lumber/sheet material section, but rather near the finished shelving material. I suspect it's intended to be used as the back of a shelving unit. One side is covered with white vinyl. The sheet was 49" x 97" (an inch larger than 4'x8'), for about $15. As far as I can tell, it -is- MDF.
The vinyl stuff pulls right off easy enough, leaving a surface that is rougher, not quite like the smooth surface you normally find on MDF, but I just used that surface as the inside of my x-axis box. Seemed to work fine, and that surface probably took the glue better.
Gary
Old 09-26-2007, 05:28 PM
joecnc2006's Avatar
www.joescnc.com
joecnc2006 is on a distinguished road
you can use 1/2 mdf or other material for the skins the main thing to remember it is a torsion box and gluing the box up provides opposite forces for the top and bottom, others have 1/2" mdf with no problems at all.
Joe
Old 09-26-2007, 05:30 PM
Moderator
bp092 is on a distinguished road
As joe said. If you can't find anything local post your city/state ille find you a supplier. MDF is supplied basically everywhere, you might have to just look around in your area for it but it's probably there.
"low end" HF Spindle or "high end" router for about $1000? biomed_eng DIY-CNC Router Table Machines 14 01-06-2012 01:15 AM
BattleAxe "aka" Ball and Chain "aka" the wife. ZipSnipe CNCzone Club House 48 05-18-2008 10:53 AM
Has anyone looked at the "JET" or "Shop Fox" manual machines? boosted General Metal Working Machines 12 03-04-2007 10:33 PM
Vertical system "jerks" and "bangs"?? REVCAM_Bob Servo Motors and Drives 5 06-12-2006 10:09 AM
Add "View New Posts" to "Main Menu" Mr.Chips Forum Questions or Problems 4 04-21-2004 11:54 PM
