Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > Joes CNC Model 2006
  #37   Ban this user!
Old 04-08-2008, 10:06 AM
tauntdesigns's Avatar
tauntdesigns is on a distinguished road
To reverse a direction in Mach.
Click on 'config' select 'homing/limits' then click in the 'reversed' column of the axis that needs to be reversed.
Jack
Walking is highly over-rated
  #38   Ban this user!
Old 04-15-2008, 10:16 PM
kb18951452 is on a distinguished road
First Cut
Alrighty,
I officially made my first "Cut" today with my machine. I bought the same router that Joe has (2.25 HP Hitachi) and found out that my end mill requires a latrger collet than my router came with. I guess i can get a set of collets? Or maybe i buy bits that requite only one collet size? Never bought them before, someone mind filling me in?
I machined a Pocketed Circle the diameter of my Router to make a router holder (Right now i am strapping the router to the Z with thosemetal screw belts, whatever they are called)
Gonna do the rest with a jig saw, i think, unless Joe reads this and has his original files for cutting out the part.
My material was HDPE (leftovers from the machine construction) ran it at 150 IPM with a .05" cut depth (thats cause i was using my 1/4" drill bit
Ran great, shavings all over the place. Next, probably a vacuum system, or soemthing.
Joe, Do you have problems with letting shavings go in the intake on your router? i put a sock over the top of mine.
ok, all for now.
  #39   Ban this user!
Old 04-15-2008, 11:17 PM
Glad to hear you're up and running,
Jack
  #40   Ban this user!
Old 04-22-2008, 12:00 AM
Changing Tools?
How is everyone else changing tools during a job?
I am having a had time lining things up, and so when i get the new tool into the router i am having a hard time getting my tools lined up. I have been trying to just run my bit down to the surface of the material and zeroing my Z again, but i am having trouble where even when do that i end up with things not quite right......
How is everyone else changing tools?
Anyone have an ATC?
  #41   Ban this user!
Old 05-01-2008, 10:11 PM
Things I have learned.
Ok, So i have been working with the machine for a while.
There are a few things i am running to, things that i am having trouble with.
I am having some trouble with several things. So.... so now i have several questions.
First off, i have no idea how to price the things i am making. How are others deciding how much to charge for things? Do yall work with Machining time? And if so, then how much per hour? Are you making signs? Cabinets? What?
I am having a tough time figuring prices.
So there are several other things i am having trouble with. When i use an Endmill to bottom out a cut in VCarve, and use a VBit for the rest of the job, i am having trouble with the Endmill doing uneven work on the milling. I am thinking it might be some slack in my machine, gonna mess with my Z Axis tommorow. Maybe someone has had some trouble.
Ok, Those are the questions i have, Maybe someone wouldnt mind pointing me to a nice pricing guide.
Old 05-01-2008, 10:28 PM
joecnc2006's Avatar
www.joescnc.com
joecnc2006 is on a distinguished road
depends on what you are making as to how you price things out, give some examples of your work or pictures of it.
Joe
Help With Turbo Cnc Near Dallas Texas dan dimock Mentors & Apprentice Locator 5 04-12-2009 06:39 PM
Any CNC Builders in Austin Texas Mr.Chips General Metal Working Machines 1 01-03-2007 09:49 PM
Houston Texas ginamc Mentors & Apprentice Locator 14 06-22-2005 03:19 AM
Any CNC Builders in Austin Texas Mr.Chips DIY-CNC Router Table Machines 24 10-15-2003 10:48 PM
Looking for M&M Systems in Texas Fish CNCzone Club House 0 09-03-2003 07:09 PM
