Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > Joes CNC Model 2006
  #61   Ban this user!
Old 10-18-2009, 03:14 PM
rdhharm is on a distinguished road
Kent,
Very nice I to would like some more INFO on your process.
Thanks,
  #62   Ban this user!
Old 10-18-2009, 11:15 PM
calgrdnr is on a distinguished road
Hello Ger and Rick.
I find picture I like , Photoshop till it is as close to stencil like , i.e. black area needs to be connected . what I can't get in PS I do with Aspire, Node edit ( VCP would work) I then cut in .25 MDF you can get thinner lines if needed ( if vectors nice and fat use .125 HDF cheaper
Flat black is best. I just use black primer drys fast and is flat .
Hope that is not to simple if need more info please ask.
please post if you make something
Old 10-19-2009, 08:12 AM
ger21's Avatar
I didn't realize they were 1/4" thick. I thought you figured out a way to route a thin film.
  #64   Ban this user!
Old 10-19-2009, 09:32 AM
Nope, But I suppose on could use vinyl cutter attachment and cut these from window tinting material ...
  #65   Ban this user!
Old 10-29-2009, 04:54 PM
another lithophande
Merged two photos using Aspire from Vectric to crate this lithophane
Name:	Howling Blk back  web.jpg‎
ID:	92239   Click image for larger version
Name:	howling out the window.jpg‎
ID:	92240   Click image for larger version
ID:	92241   Click image for larger version
  #66   Ban this user!
Old 12-13-2010, 09:08 AM
Aztec calander
OK you guys must be completing something Everyone like the aztec calender I did this a while back. OK your turn to share
Name:	Corian unpainted15.5 dia .jpg‎
ID:	121337   Click image for larger version
Name:	Painted hammered copper.jpg‎
ID:	121338   Click image for larger version
Name:	sanded the suface15.5 dia.jpg‎
ID:	121339   Click image for larger version
Name:	end table.jpg‎
  #67   Ban this user!
Old 12-13-2010, 10:58 AM
bsimages is on a distinguished road
Here is something I did last summer.
Vectric Forum • View topic - My First Rotary Attempts
  #68   Ban this user!
Old 01-24-2012, 08:37 PM
cutter100's Avatar
cutter100 is on a distinguished road
First litho
( old thread hope ur still watching) Hi all, This is just a practice piece on a piece of cutting board, hence all the dark lines and how rough it looks. The pic came from plasmaspider site. this was my first try at litho's and I'm STOKED at what can be done. I have some corian that I'll use next and post that as well.
Taped the material down with 3m double sided carpet tape from home depot and had at it. Took about 1.5hrs at 40-60ipm, I would change speed as the router got closer to the bottom or top since the lines were shorter.
Thanks for the machine Kent, still working great.
Chris.....Everyday is a Good day.....if you wake up breathing!
Joe's 2006, Mach3, Vectric software.
  #69   Ban this user!
Old 01-28-2012, 09:45 AM
Looks good Chris , Glad to you are using it
be sure to post more ...
  #70   Ban this user!
Old 02-24-2012, 07:46 PM
cutter100's Avatar
Smile Here's number 2
This ones a little thick , 1/2" corian ( maybe avonite) , but for practice I find stuff for free and use it. Guess I could "shave" it down so the light would penetrate better but for now I can see what a difference the material can make. Time to get shopping on ebay.
Took about 5 hrs. and used (believe it or not ) a deburring bit I got at ace hardware for 20.00. for the final. 1/4" round nose for the rough. Can't wait to get some real good v-bits. Coming soon.
PS; Thats a pic of my daughter when she was 6yrs old. 5 yrears ago.
Name:	cassi litho.jpg‎
  #71   Ban this user!
Old 02-29-2012, 12:01 AM
cutter100's Avatar
This time I went small. Got a better bit too, 30deg v-bit from a guy at a swap meet for $5.00. ( hope it doesn't break for a while) I had requested some samples from an avonite dealer and got them in the mail within a week! They were 2x4x 1/4" so this is 2x2.
It helps to have a good bit I see.....lol. Sorry about the focus.
ps; re-cutting the 5x7 to 1/4"
Name:	cassi small.jpg‎
  #72   Ban this user!
Old 03-18-2012, 09:07 PM
cutter100's Avatar
Gettin thinner...new litho
Well it's been 20 days, ( and with my schedule that's pretty good) but here's one of my sister's grand daughter. Back drop is Miami condo/hotel from the intercoastal.
Went down to .04 from base but I think I'll stay at .08 . Good light at .04 but the pixels seem to come through more too. Still working on it so "subject to change".....lol
ID:	155377   Click image for larger version
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
malcf
RFQ: NY/NJ Area lathe work needed.(Completed) smythe Employment Opportunity 2 03-26-2007 10:34 AM
Lathe Work for 20 pieces stang5197 Employment Opportunity 6 09-26-2006 10:10 PM
Milling work to square up pieces mrbaseball Employment Opportunity 4 01-23-2006 01:07 PM
*WORK ASSIGNED* RFQ - 2 pieces CNC'd aluminum emblem dallas4u Employment Opportunity 20 01-13-2006 07:41 PM
COMPLETED RFQ Lathe work dmgdesigns Employment Opportunity 1 11-09-2005 04:05 PM
