#29
Composite decking is about as stiff as a wet noodle and quite heavy. You might get some sagging if you go that route.
#30
| here is exaple of where the composite material will be placed as shown in red in photo. Joe |
#31
| How much wobble do you get on the table since the MDF isn't screwed down and there isn't any triangulation to keep it rigid?
__________________ Mark -------------------------- Check Out My Build-Log(s): http://cnczone.com/forums/showthread.php?t=4716 CNC Router Version 1 [====================] 100% http://cnczone.com/forums/showthread.php?t=39294 CNC Router Version 2 [=|-----------------------] 5% |
#32
| Ok, i guess i will explain a little further. The composite material is cut into strips, slide into uni-strust (as shown red in above picture) which will extend above the top of the uni-struts, It is bolted to from the bottomto the uni-struts, then i will machine the top portion skimming it with the machine to level it with the gantry, then the mdf bed will screw down to the machined composite material, when done this should be very stable with no movement. and when i cage in the legs of the router with a lower shelf across the machine it will make a very solid frame. Joe |
#33
| Howdy Joe, Ok, how about something like this, keep in mind I'm not a CAD expert and I tried to come up with something based on parts used with your 2006 machine. This did add 1 1/2 inches to the overall height, but the back plate remains at the specified dimensions. 2004 ACAD File z_axis_slide.dwg 2000 ACAD File z_axis_slide_2000.dwg Like I mentioned before I've also been planning a mod to my existing machine or maybe a new machine so any suggestions are always welcome! ![]() Bob |
#34
| Well, I do like Bob's drawings, and is similar to what i eventually want, I did a quick bolt on Z-Axis, until i can refine the other design exactly like i want and maybe out of alumn. This is a simple bolt on Z-Axis Slide and also the motor mount is bolted from above. It works well. and i have room for adjustment on the router mount at different bolt on heights. I found this was needed especially if you use the ATC. Joe |
| Currently Active Users Viewing This Thread: 2 (0 members and 2 guests) | |
| Drive for 3-phase hybrid stepper motor | Newbie2CNC | General Electronics Discussion | 9 | 08-13-2009 07:20 AM |
| New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter | the__extreme | CNC Wood Router Project Log | 3 | 02-26-2007 03:58 PM |
| cnc router Joe's kit | woodrow | Joes CNC Model 2006 | 1 | 01-05-2007 11:20 PM |
| TESTING A HYBRID IC dv06 | 69owb | Fanuc | 0 | 05-26-2006 05:12 PM |
| hybrid go-cart funding | keebler303 | CNCzone Club House | 15 | 04-09-2006 09:00 PM |
