Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > Joes CNC Model 2006
  #13
Old 05-31-2007, 09:18 AM
spalm's Avatar
Gold Member
spalm is on a distinguished road
Hey Joe, looking good.
I really like the pipes on the top and bottom of the lower rails (your Y?) instead of the sides. It solves a few problems in my mind. I guess the bottom trucks are the adjustable ones? How are you attaching the bottom pipe?
I don’t see a leadscrew attached to your Z carriage. Where are you planning to attach to it (top, bottom, back)?
Edit: Now I see it. Ooops, nevermind.
I have been playing with a set of V-bearings for my 6 inch wide Z. I went with official rails. They are $1 an inch, but you only need two 1 foot (or so) sections, so the total price is not that bad. IMService cut them to length for no additional charge. I mounted them on wooden standoffs. The eccentrics only give you .048” of adjustment, so the rail standoff placement and parallel is critical. My first design had the motor riding up and down with the router, but I think I talked myself out of that.
I went with split rails on my Y to allow greater adjusting. This could also be used for your Z and then you would not have to buy the bushings.
Good Job,
Steve
ID:	38266   Click image for larger version
Last edited by spalm; 05-31-2007 at 10:32 AM. Reason: eccentrics give 2x .024 = .048
  #14   Ban this user!
Old 05-31-2007, 11:55 AM
sdantonio's Avatar
sdantonio is on a distinguished road
Joe,
Very cool, can't wait to see what it will do when it is complete.
If you cut it to small you can always nail another piece on the end, but if you cut it to big... then what the hell you gonna do?
Steven
  #15   Ban this user!
Old 05-31-2007, 12:43 PM
BobLWeiss is on a distinguished road
Nice design Joe!
Can I ask how you managed to connect the pipe/rails for the Y and X to the support pcs? It looks like you have some sort of plastic spacers between the two but how did you connect it?
Bob
  #16   Ban this user!
Old 05-31-2007, 01:39 PM
Smackre is on a distinguished road
Looks great joe.
Old 05-31-2007, 02:56 PM
joecnc2006's Avatar
www.joescnc.com
joecnc2006 is on a distinguished road
Here is a picture of how the X and Y Rails are made, hope this helps, using 10-24 screws drill and tapped into pipe rails every 6".
and a shot from the side of the caraiage slide.
Yes the Y-Axis carriage has the tensioning bolts on the bottom, i figured that would be best.
Joe
ID:	38283   Click image for larger version
ID:	38284   Click image for larger version
ID:	38285   Click image for larger version
  #18   Ban this user!
Old 05-31-2007, 05:34 PM
srstol is on a distinguished road
I like it. How are your two y-axis lead screws syncronized?
Rob
Old 05-31-2007, 07:26 PM
joecnc2006's Avatar
www.joescnc.com
Rob
Mach3 and timing belt
  #20   Ban this user!
Old 05-31-2007, 07:44 PM
ccsparky is on a distinguished road
Here's my submission for the z-axis. All attempts for accuracy have been made, however I would highly suggest that all measurements be double checked.
The bolt head measurements are from some bolts that I have, however I found three different sizes so I went with the one I had the most of and that seemed to be the most common.
These ideas were what I was thinking of for a future mod to my existing machine or for a new machine. I drew these with the dimension as suggested by Joe.
Hopefully the drawings will provide some useful information.
Saved as version 2004
z_axis.dwg
Saved as version 2000
z_axis_2000.dwg
Bob
Old 05-31-2007, 07:55 PM
joecnc2006's Avatar
www.joescnc.com
Attachment 38301
Attachment 38302
Bob
Looks good, now need to factor in leadscrew anti-backlash and motor mount ontop. as a complete Z-Axis assembly, but the concept is good.
Joe
  #22   Ban this user!
Old 05-31-2007, 08:08 PM
Joe
Ok, that'll be next, got a little ahead of myself, always one more thing to do...
Joe, those rail mounts and the way you use them with the aluminum is really nice! Great idea!
Bob
Old 05-31-2007, 10:26 PM
joecnc2006's Avatar
www.joescnc.com
Here is a shot of showing the rear of the Gantry.
Joe
Old 05-31-2007, 11:28 PM
mvaughn's Avatar
Moderator
mvaughn is on a distinguished road
A bigger table, yet you'll be able to use smaller boxes when you ship the kits...
Seriously, superb work Joe!
Mark
Check Out My Build-Log(s):
http://cnczone.com/forums/showthread.php?t=4716
CNC Router Version 1 [====================] 100%
http://cnczone.com/forums/showthread.php?t=39294
CNC Router Version 2 [=|-----------------------] 5%
Drive for 3-phase hybrid stepper motor Newbie2CNC General Electronics Discussion 9 08-13-2009 07:20 AM
New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter the__extreme CNC Wood Router Project Log 3 02-26-2007 03:58 PM
cnc router Joe's kit woodrow Joes CNC Model 2006 1 01-05-2007 11:20 PM
TESTING A HYBRID IC dv06 69owb Fanuc 0 05-26-2006 05:12 PM
hybrid go-cart funding keebler303 CNCzone Club House 15 04-09-2006 09:00 PM
