Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > Joes CNC Model 2006
  #1369   Ban this user!
Old 01-14-2012, 08:34 AM
bgriggs's Avatar
bgriggs is on a distinguished road
Originally Posted by racedirector View Post
Well I did it, I just bought the plans. Still not 100% sure I will build one yet but it is between a 2x4 / 2x6 cutting area Hybrid, a LionClaw LC50B or a Joes 2006....
Congratulation and welcome. If you want to see a thread with lots of details and an index to make things easy to search, check out my thread. It is located under built complete r&p section. Bgriggs is also my screen name.
Bill
Joescnc 4x4 R&P Router, Minimill, Minilathe, CNC Foamcutter, laser cutter, Vectric Aspire. http://makermasters.com
  #1370   Ban this user!
Old 01-14-2012, 07:07 PM
racedirector is on a distinguished road
Bill
Thanks Bill
Had the plans waiting for me on email this morning, am just completing the registration on the forum. I will definitely check out your build! Lotsa reading to do, I can see what I'll be doing for the next week or so
Cheers
Bruce
  #1371   Ban this user!
Old 01-14-2012, 11:06 PM
bgriggs's Avatar
Thanks Bill
Cheers
Bruce
Bruce,
Let us know how you like/dislike your experience. Many people would like an unbiased opinion from a new member.
Bill
  #1372   Ban this user!
Old 01-18-2012, 10:31 PM
Hi Bill
Missed this post sorry. Ummmm, which experience - the plans or the support forum?
Cheers
Bruce
  #1373   Ban this user!
Old 01-18-2012, 10:34 PM
bgriggs's Avatar
Hi Bill
Cheers
Bruce
Folks would like to hear about both. Your choice though.
Bill
  #1374   Ban this user!
Old 01-18-2012, 11:52 PM
Ok, I'll get my thoughts together and post in the support forum. Will more likely be my experiences from looking for Australia builds but may include some overalls too....
  #1375   Ban this user!
Old 02-19-2012, 11:59 AM
hockeyguy01 is on a distinguished road
Wanting
But i have a few questions before i do. I hope this is the place to ask!! what is the difference in Joes model 2006 and the joes model 4X4 is it the size of the machine? also trying to find a good link to elaing the differnce between Rack and Pinion and leadscrew. I want to cut oak, maple about 3/4-1 inch stock i want to have the larger bed to have a table to cut many parts in one layout table. Any info would be great thanks
  #1376   Ban this user!
Old 02-19-2012, 12:11 PM
atwooddon is on a distinguished road
The difference is in the cutting area of the 2 machines and the construction technique. The 2006 is roughly 2ft by 4ft and the Hybrid is approx 4ft by 4ft. The Joes 2006 is a machine built primarily from MDF and can be built with simple tools if you are careful with your work. There are many people that have built the 2006 and several build threads here on CNCZone. The Hybrid is a newer model and is probably a little more robust (rigid) with a larger cutting area. The 2006 is driven with lead screws (threaded rod driving a threaded nut) while the Hybrid is rack and pinion which is basically a toothed round gear running along a toothed linear rail. The teeth mesh and that is what provides the moving force and accuracy. Cost of construction is also a difference with the larger size and more robust construction making the Hybrid more expensive to build.
Either machine is capable of cutting the oak or maple.
I would recommend you read thru a couple of the build threads to get a more detailed idea of how each machine is built.
Good Luck
Don
  #1377   Ban this user!
Old 02-19-2012, 12:23 PM
thanks for the response to my ?
I was begining to think that i was posting incorrectly here. If you were to build a machine 4x8 in size what Joe Design should i order. Your opinion would help me out i want to start building ASAP.
And would you build it with a rack and pinion or leadscrew. I would eventuly like to build with some 3d programing. accuracy between .005 is all i really need i would think. I have a solid metal table 3x8 And would like to build on top of this. If you recall any good links for this design that would get me to a good place to start reading. I want to order some plans buy the end of the day!
Thank you
Old 02-19-2012, 12:49 PM
ger21's Avatar
The 2006 can not be built to a 4x8 size.
If you want to build the Hybrid on a table, the design will need to be modified I think.
A 4x8 hybrid should be rack and pinion.
  #1379   Ban this user!
Old 02-19-2012, 02:27 PM
bgriggs's Avatar
Thank you
Build the hybrid. It can be built on top of your existing table provided that it is Square and can be drilled into. There is no contest between the two designs. The Hybrid is the way to go.
Bill
  #1380   Ban this user!
Old 02-19-2012, 04:10 PM
curtis is on a distinguished road
I built the hybrid and quickly found I needed a full 4x8. I added on to the basic design with ease just by adding on a few more pieces. The design is that good.
Then the access to the hundred plus build logs is what makes it all go so well.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
dodger889
Drive for 3-phase hybrid stepper motor Newbie2CNC General Electronics Discussion 9 08-13-2009 06:20 AM
New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter the__extreme CNC Wood Router Project Log 3 02-26-2007 02:58 PM
cnc router Joe's kit woodrow Joes CNC Model 2006 1 01-05-2007 10:20 PM
TESTING A HYBRID IC dv06 69owb Fanuc 0 05-26-2006 04:12 PM
hybrid go-cart funding keebler303 CNCzone Club House 15 04-09-2006 08:00 PM
