Page 1 of 2 12 LastLast
Results 1 to 12 of 22
Thread: Anyone tested milling soft aluminium with Joes CNC?
    May 2007
    Sweden
    Hello,
    Im planing to build Joes CNC router as a project in school after the summer break since i think it is one of the most detailed projects here on cnczone and fitīs my needs for doing some wood/plastic cnc things. But as the title read is there anyone that have tested machining soft aluminium with this cnc machine?
    Could be cool to know if it has been done and if someone did get it to work so please inform me about this.
    Regards,
    Viperia
    Registered trajan's Avatar
    Mar 2006
    Machining aluminum with a router
    Viperia, I believe that the rotational speed of a router is much to fast for machining aluminum. I have a mill and machine aluminum at approximately 300 RPM. The recommended router (Hatachi) for Joes CNC router has variable speed of 8,000 to 24,000 RPM.
    After I get my Joes router done I plan design a motor mount system for a DC motor I bought on eBay. I will buy a 90 Volt speed controller and try to machine aluminum. The collet mechanisum will be challenging.
    Richard
    May 2007
    Sweden
    Well i know the speed of the hitachi router is to fast but thought maybe someone has used another router on his build.
    Regards,
    Viperia
    Dec 2005
    Milling alum is possable. I seen a guy do it on a machine like joe's first model. He used very small tools so that got the rpm up alot. I have a commercial machine and i run 8k rpm on a 3/8 tool for alum and it works pretty well. I also use compressed air to blow the chips out.
    As for milling alum on a router. Id advise using a roughing end milling as much as possable. Roughers cut at prolly 20% the pressure of a finish tool. I cut alot of parts out with rougher only. And use coolant if possable or air to at least remove the chips. Hardest thing about milling alum is keeping the chips from gualing up the tool.
    But I do not advise milling alum on a regular basis on a home built machine. I would think it would vibrate your machine to death.
    Hope this helps you out.
    Mar 2003
    Shelby Twp, MI....USA
    Quote Originally Posted by trajan View Post
    You can buy router bits for cutting aluminum at router speeds. www.onsrud.com
    Dec 2005
    Those onsrud bits call for a 300-400 cutting speed right? I do not think thats possable on a home built machine. Running them slower might burn the bits up.
    Mar 2003
    Quote Originally Posted by Smackre View Post
    Depending on the tool, they recommend chip loads from .002-.010.
    A single flute tool with a chip load of .005, at 15,000 rpm = 75ipm feedrate. With an 8000 rpm router you can get down to about 40ipm.
    Dec 2005
    where do you get recommended chip load for the onsrud bits? I am looking at there single flute o alum cutting tools but I dont see chip loads anywhere.
    Mar 2003
    In the back of their catalogs.
    Or here:
    https://www.onsrud.com/xdoc/ChipAluminum
    Dec 2005
    Thanks for the info. Even with those tools I would think it would be tough to mill alum on a homemade machine. Even one as Good as Joe's. I would think you would need linear rails to mill alum.
    Jan 2006
    K2CNC has 3 videos of milling aluminum with a PC router...
    http://www.k2cnc.com/Videos_CNC.asp
    May 2003
    Hitachi M12VC router, 24,000 RPM, 1/4" triple flute flat endmill, 80 IPM.
    Trapaezodial belt driven X axis no less....
    No problem...
    Attached Thumbnails Attached Thumbnails Anyone tested milling soft aluminium with Joes CNC?-cid_004f01c79b4f%24cec77bd0%240300a8c0%40barton.jpg   Anyone tested milling soft aluminium with Joes CNC?-cid_005001c79b4f%24cec77bd0%240300a8c0%40barton.jpg   Anyone tested milling soft aluminium with Joes CNC?-cid_005101c79b4f%24cec77bd0%240300a8c0%40barton.jpg   Anyone tested milling soft aluminium with Joes CNC?-cid_005201c79b4f%24cec77bd0%240300a8c0%40barton.jpg
  • Page 1 of 2 12 LastLast
    1. Wood Router Photos 99% complete and tested.
      By CJL5585 in forum DIY CNC Router Table Machines
      Last Post: 12-21-2008, 01:04 PM
    2. And another 2 joes
      By sdantonio in forum Joes CNC Model 2006
      Last Post: 04-19-2007, 02:54 PM
    3. DIY Aluminium milling anyone?
      By Oldmanandhistoy in forum DIY CNC Router Table Machines
      Last Post: 10-21-2006, 10:56 AM
    4. Recommendations for milling thick aluminium
      By Rhodan in forum Mechanical Calculations/Engineering Design
      Last Post: 09-03-2006, 09:14 PM
    5. milling aluminium without coolant ?
      By andy55 in forum General Metalwork Discussion
      Last Post: 10-19-2005, 09:00 AM
