Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > Joes CNC Model 2006
  #25
Old 05-30-2007, 07:37 AM
joecnc2006's Avatar
www.joescnc.com
joecnc2006 is on a distinguished road
Originally Posted by BobLWeiss View Post
Thanks Joe for the tip. I did read that thread and keep up with it. The only problem I have now is that I only filed down the ends of the Y axis rod to fit the bearings and not the whole rod so adding a bearing on the other side of the carriage assembly isn't going to work unless I file the whole thing first.
The good thing about the 1/2"x10 5 start rod is that it doesn't need filing. Its just like the 1/2"x10 1 start rod in terms of diameter.
I might make something out of HDPE and use that intead of an actual bearing. I can then make the hole a tad larger than 1/2" to fit the rod.
Bob
Yes i had the same problem, thats why i made mine out of Delrin so it would last a while.
where did you get your 1/2"-10 five start?
Joe
  #26   Ban this user!
Old 05-30-2007, 07:47 AM
BobLWeiss is on a distinguished road
Same place I got the other one. MSC. It was something like $70 for a 6 foot rod. I am using dumpsterCNC's anti-backlash nuts on it too. I should be able to get it installed tonight when I get home from work. I got the pipes installed yesterday and everything seems to line up nicely so far.
Can you share your files for the anti-whipping blocks? It would save me some time.
Thanks,
Bob
Old 05-30-2007, 11:35 PM
joecnc2006's Avatar
www.joescnc.com
Here is a simple one i made. Stock is 0.50"
the v-carve, DXF and tap files zipped.
Even if you do now own V-Carve pro you can view it with the trial version i believe.
Joe
Name:	Delrin for leadscrew.jpg‎
  #28   Ban this user!
Old 05-31-2007, 07:25 AM
Thanks Joe!
I got the X axis working last night... what a BIG DIFFERENCE the new leadscrew makes. I am getting 250+ IPM rapids and its so smooth and quiet! There is absolutely no whipping in the X axis. It was definatly worth the effort.
I am going to finish putting together the bed tonight and start cutting some test cuts.
Bob
  #29   Ban this user!
Old 06-01-2007, 03:45 PM
Just about finished!
Here are pictures of the completed machine. I added 2 pieces of birch plywood on top of the top deck sides to prevent dust from getting on the rails of the X axis. The reason I choose the plywood was because I am going to screw down T-Tracks and the MDF doesn't take screws too well.
Next up is the electronics. I already have the drivers and power supply working from my previous machine but I wanted to put it all neatly in cases. I will post pictures of that this weekend.
Bob
ID:	38351   Click image for larger version
ID:	38352   Click image for larger version
ID:	38353   Click image for larger version
Old 06-01-2007, 07:38 PM
joecnc2006's Avatar
www.joescnc.com
Thats a nice looking machine, Hope you get alot of enjoyment out of it.
Joe
  #31   Ban this user!
Old 06-02-2007, 03:29 AM
santiniuk's Avatar
santiniuk is on a distinguished road
Great to see you back on the scene Bob.
Quite a transformation from the 1st machine. Paint job looks great !
Looking forward to seeing it in action.
Cheers
  #32   Ban this user!
Old 06-02-2007, 08:37 AM
Thanks!
Yes this is a BIG improvement from before. I finally got a house with a garage so I have the room for the larger machine.
Working on the electronics today..will post pictures of that setup soon.
Bob
