Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > Joes CNC Model 2006
Old 03-14-2007, 06:47 AM
rdhharm is on a distinguished road
Joes CNC Allendale, MI
Hi all I have started a Joes CNC model I final have time to post pictures of my build.
But before I start I have to say hats off to Joe for sharing his idea and files with all of us. Beasuse if he didn't all of us wouldn't have build this machine.
So I have to say Thank You Joe.
Well this is my CNC is just about to ready to make saw dust with a good weekend coming up I just waiting on some parts.
So it is up to all of you on how fast that I post pictures I can post them slow or fast.
But I will start with a pile of parts. It is hard to believe that you start with a pile of parts and it can make what every your mind can dream up.
Rick
ID:	33526   Click image for larger version
ID:	33527   Click image for larger version
Old 03-14-2007, 08:45 AM
ccsparky is on a distinguished road
Rick
Welcome to the club Rick!
Looks like you're ready to go! If it's up to us, then I say...
Take your time with your build, but post your pictures fast!
We all like pictures and lots of them!
Have a great time! Look forward to watching your progress!
Old 03-14-2007, 09:47 AM
joecnc2006's Avatar
www.joescnc.com
joecnc2006 is on a distinguished road
Looks good so far. I see the Long axis ribs for the X-Axis is made slightly different from mine, i have the splices further apart from each other stagered at the furthest ends, I did not want to chance of any boxing with having the splices towards the center, but if you use 1/2" MDF as the skins you should be alright.
One more question what material are the Bearing blocks and anti-backlash nuts? they have a blue center.
Look forward to seeing more on the build.
Joe
Old 03-14-2007, 08:02 PM
Wink
Joe
Hi Joe well as for the long ribs that was a big as we could make them on the router that was used to make them. On the bottom I used 1/4 masonite glued and pined nailed. I will do the same to the top and add a piece of 3/4 particle board screwed down so I don't think it will move.
As for the material used for the bearing block I don't see any blue
just kinding LOL. I don't know for sure it is very close to the HDPE and is used to make signs so if it can take the weather up here I think it will do just fine the Letterguy can answer that question he is the one that cut the parts for me.
Here are a few pictures of a jig that I made for the bearings slides so I could used a router with a 1/4" bit.
Let me ask all of you if you had one thing to tell a newbie not to do that you may have done while you were building your CNC machine what would that be?
I would say when you make your bearing slides take your time double check make sure you are 100% right because if your off 1/16" they will not work.
Rick
ID:	33537   Click image for larger version
ID:	33538   Click image for larger version
ID:	33539   Click image for larger version
Old 03-14-2007, 10:00 PM
HayTay's Avatar
HayTay is on a distinguished road
rdhharm,
It looks like you blasted the bearing slides with some kind of media (referring to PIC #3 above). They look real nice. What media did you use? It doesn't look like they were blasted with sand (big NO, NO on that one from OSHA).
Keep up the good work and thanks for joining in on CNCzone!
HayTay
Don't be the one that stands in the way of your success!
Old 03-14-2007, 10:34 PM
Moderator
bp092 is on a distinguished road
Hay, info on the osha deal with that?
Bearing slides look good. You can be off a bit and they will still work, but the more exact you are with them, the less adjustments you will need to make. If you make them perfect to the drawings you literally just have to tighten them enough. If you are like me butchering them with woodworking bits, (lol) you have to play with tightening them in pairs and what have you.
Old 03-14-2007, 11:25 PM
HayTay's Avatar
http://www.osha.gov/dcsp/ote/trng-ma...sis/si_gi.html
http://www.osha.gov/Silicosis_Conference/nr961031.htm
http://www.osha.gov/pls/oshaweb/owad...able=STANDARDS
I used to work at a company that used 'real sand' for blasting/finishing cast aluminum parts. Even though we were using a ventilated blasting cabinet the sand dust (free silica) was everywhere, and I mean everywhere. Our insurance agent and an OSHA representative showed up within 2 weeks of each other, both men STRONGLY RECOMMENDED (hint, hint, nudge, nudge) that we switch to a different media before their follow up visit and final reports. They both suggested switching to walnut shells, recycled buttons (plastic), aluminum oxide and several other media. After trying various media samples we settled on, and switched to, aluminum oxide.
Be careful if you're using sand, it, along with the potential for silicosis, is some nasty stuff. I hope you find the above links informative.
HayTay
Old 03-15-2007, 06:04 AM
Originally Posted by HayTay View Post
rdhharm,
No they weren't sand blasted I used my Orbit Sander. I know all about silica we use products everday that have silica sand in them.
Rick
Old 03-15-2007, 06:07 AM
Yes you are right but if they are off in opposite corners that is a lot to be off
and they will not ride on the pipe square. I found out the hard way I had to remake some.
Rick
Old 03-15-2007, 06:45 PM
joecnc2006's Avatar
www.joescnc.com
I always use a templete and center punch the holes.
  #11   Ban this user!
Old 03-15-2007, 08:25 PM
Here are some pictures of how I glued my X & Y torsion box ribs together I made a jig with some scrap pieces of plywood and a piece of particle board to keep them square. They came out right on the money for square.
Rick
ID:	33586   Click image for larger version
ID:	33587   Click image for larger version
ID:	33588   Click image for larger version
ID:	33590   Click image for larger version
ID:	33591   Click image for larger version
  #12   Ban this user!
Old 03-15-2007, 09:09 PM
Mini HVLP Spray Gun!!!! I spent two weekends painting my machine using spray cans from Lowes. I lost count of how many cans of primer and white paint I used. I've since purchased a mini HLVP spray gun and have to say it's worth every penny and the results are much better! I would venture to say that using the HVLP gun I could have painted everything in a matter of hours versus days, and when I say it's worth every penny, I don't mean to make it sound expensive. I purchased a two gun kit from Grizzly for less money than I paid for all the cans of paint!
Well their you have it, my one thing! Oh did I mention I hate to paint...
Joes CNC Model 2006 R-1 joecnc2006 Joes CNC Model 2006 198 11-14-2011 09:49 PM
Joes 2nd Machine joecnc2006 CNC Wood Router Project Log 194 06-11-2007 11:08 AM
Joes Machine...Is there a kit? slackkeymike Joes CNC Model 2006 8 02-27-2007 08:23 PM
