Hi Group I'm going to take the plunge and make a Joe2006. Angle Iron Bearing Support Question: The PDF file drawings do not show : 1) All The necessary dimensions to place the hole for the bolt to hold the bearing (For Example - on th Z Axis Bearing Support - it shows tha the holes are placed in 0.375 and 1.125 inches in from the end (say X Dimension) but does not give a Y-dimension. Looks to be around 1/2 or 5/8" on the 1.25 " side of the angle iron. 2) Don't show the dimensions of the hole (believe it to be 0.25") Any help is appreciated. Joe |
I too am having a little trouble with the dimensions of the slide bearings. I can't seem to find a pdf with the drawings of them anywhere. Can someone point me in the right direction? Thanks, John aka clueless newb |
| The bearing bolt holes are for a 5/16" bolt, just drill 5/16. And 1/4" for the rail mounting holes. The 0.433" dimension is the most critical - it's half the diameter of the bearings. If you get it right, the surface of the bearing will perfectly match the opposite side of the angle. But, it's probably more critical that they be identical than exactly 0.433. Ten mils off either way probably won't matter as long as they are all off the same amount - I finally used a drilling jig to control that dimension. Gary |
| If you do a search for "print dwg" or "print dxf" you'll find software that will print DWG files. Then you should be able to print Joe's orginal DWG files to scale. AutoDesk has DWG Trueview that allows you to view and I believe print to scale at this link: http://usa.autodesk.com/adsk/servlet...&siteID=123112 Bob |
#11
| http://www.lumenlab.com/~joe2000chev...odel_2006_R-1/ It's about the 4th link down just below the avi movie. Bob |
#12
| Just looked through the DWG files again and I do not see the XYZ Bearing Support files. Just to be sure I am talking about the aluminum angle parts that hold the bearings. I may be calling them the wrong thing. Thanks Glenn |
| 4th axis support in BobCad | P40Sortie | BobCad-Cam | 8 | 09-18-2006 02:58 PM |
| Newbie leadscrew support/bearing question | lukaslouw | DIY-CNC Router Table Machines | 0 | 09-23-2005 11:03 AM |
| gas pipe & linear bearing dimensions relationship | zoltan | Linear and Rotary Motion | 6 | 06-13-2005 04:12 PM |
| does Mastercam support 5 axis ? | Calico | Mastercam | 1 | 05-03-2005 04:08 PM |
| Does Onecnc support 3+2 axis? | Dan B | OneCNC | 1 | 02-25-2005 05:03 PM |
