Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > Joes CNC Model 2006
  #13   Ban this user!
Old 03-31-2007, 11:21 AM
calgrdnr is on a distinguished road
template
Since all the holes are same distance from left 0.375 and right side1.125. and the top of the angle 2". I juse made a template from 1/4"x1" steel.I made it same size as Z axis just align it on top and then drill ( I made the template with 5/32 holes) on other axis, just align left side clamp drill unclamp slide over to other edge (rightside) clamp and drill. flip over angle repeat...
I was having problem with not getting holes exactly the same ( cheap drill press)
Name:	templat small leftside.jpg‎
ID:	34568   Click image for larger version
Name:	template small rightside.jpg‎
  #14   Ban this user!
Old 03-31-2007, 07:04 PM
ccsparky is on a distinguished road
Glenn,
Sorry about that, I misunderstood what you were asking for.
Here are the dwg files I did to use as a template:
x_axis_bearing_support.dwg
y_axis_bearing_support.dwg
z_axis_bearing_support.dwg
I print them out using the 1:1 setting "centered" then used a straight edge and a razor knife to cut them out.
Double check the print out to verify that it's to scale prior to drilling
Bob
  #15   Ban this user!
Old 04-01-2007, 04:36 AM
Depdog is on a distinguished road
Which version of Autocad did you use. I have 2002 and it says "Drawing was created with an incompatible version"
Glenn
  #16   Ban this user!
Old 04-01-2007, 07:00 AM
Glenn
I use AutoCAD LT 2005. I've saved them to the 2000 file type this should work with all versions from 2000 up.
x_axis_bearing_support_2000.dwg
y_axis_bearing_support_2000.dwg
z_axis_bearing_support_2000.dwg
Hope this works out!
Bob
  #17   Ban this user!
Old 04-01-2007, 01:18 PM
Those work great!
Thanks to both you and calgrdnr
Glenn
  #18   Ban this user!
Old 04-18-2007, 09:28 PM
CNC-Joe is on a distinguished road
X-Y-Z Axis - For Sale? Would anyone be interested?
As I have a 2500# CNC Milling Machine at home, and would like it to start earning it's keep - I thought some people here might want to just buy the bearing mounts (the angle iron) pre-drilled accurately and ready to go.
Would anyone here be interested in buying these?
If so - what would you be willing to pay?
CNC-Joe
CNC-Joe <at symbol> comcast dot net
JoeComunale (at) Comcast.Net
CNC Is Not Just My Passion.. It's My Addiction !!!!
  #19   Ban this user!
Old 04-18-2007, 11:58 PM
erebus is on a distinguished road
I'd be willing to buy the angles precut and drilled. Not sure what the value is... I'm basically lazy so this is a way to not have to drag out the drill vise and toys and setup for this. If you come up with a price tag let me know. I'm guessing just cut and drilled they would be worth something on the order of $5 plus material cost.
  #20   Ban this user!
Old 04-21-2007, 04:53 PM
Email Sent!
Glenn
  #21   Ban this user!
Old 05-17-2007, 05:49 PM
CNC-Joe replied to the email from you.
Glenn
4th axis support in BobCad P40Sortie BobCad-Cam 8 09-18-2006 01:58 PM
Newbie leadscrew support/bearing question lukaslouw DIY-CNC Router Table Machines 0 09-23-2005 10:03 AM
gas pipe & linear bearing dimensions relationship zoltan Linear and Rotary Motion 6 06-13-2005 03:12 PM
does Mastercam support 5 axis ? Calico Mastercam 1 05-03-2005 03:08 PM
Does Onecnc support 3+2 axis? Dan B OneCNC 1 02-25-2005 04:03 PM
