Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > Joes CNC Model 2006
Old 12-09-2006, 06:55 PM
DougO is on a distinguished road
I'm in... another Joe2006 machine
I couldn't stand it. With all the compliments and pictures of Joes2006 machine, I have to give it a try. Joe is cutting out my HDPE parts and I'm working on the mdf ones. I think I have most of my hardware parts in but had problems finding the right size ubolts. Just ordered the ubolts from Amazon.com (thanks David). Have completed the bearing assemblies and have cut a few of the mdf parts.
ID:	26991   Click image for larger version
ID:	26993   Click image for larger version
ID:	26995   Click image for larger version
Old 12-10-2006, 02:20 AM
txcowdog's Avatar
Gold Member
txcowdog is on a distinguished road
That is a pretty nice looking machine you have already.
Old 12-10-2006, 01:51 PM
Moderator
bp092 is on a distinguished road
Yeah, ditto to that. Is that the sosy 3 plan design? I purchased it awhile back but liked Joe's table assembly better and the way the gantry was above the table. Loading the pieces in there seems akward to me, seems more useful to have the slides at the same level as the table and the gantry above. But that's just me. Looking forward to seeing the rest of your build. I hope more people come forward, there are many more people with Joe's parts that aren't posting them!
Old 12-10-2006, 02:49 PM
Yes, this is David Steele's Sosylva plan. It is just to slow for me. A person that knows what he he is doing could probably get more speed out of it. I can jog it around the table @50 ipm all day long but when I actually run a program it loses steps if it goes over 15 ipm. It is very accurate at the 15 ipm. I cut 3/4" mdf in 3 passes and you just about need a magnifying glass to see where each different depth of cut is made. Very smooth. After I kinda learn what I am doing I might try working on the speed again. If the Joes20006 works like I hope it does, maybe I won't have to work on the Sosylva model any more. At one time I had the Sosylva air cutting @60 ipm but it vibrated excessively I slowed the speed. It was not loseing any steps but just vibrating excessively. I'm hoping Joes2006 machine is going to be a vast improvement.
Old 12-12-2006, 02:24 AM
Getting a few more parts cut out.
ID:	27152   Click image for larger version
Old 12-12-2006, 05:10 AM
*Registered User*
DayneInfo is on a distinguished road
DougO - I have the same machine you do. I just completed the build a couple of weeks ago and am still learning and tweeking the setup. I hope you continue to update this because I built mine with the same idea in mind. Build the one I have to learn and use it to build a better one.
Dwayne
Old 12-12-2006, 12:58 PM
joecnc2006's Avatar
www.joescnc.com
joecnc2006 is on a distinguished road
Looks good so far, let me know if you need any help with anything, ie. depths of cuts or anything else.
It always does not hurt to have two machines... lol
joe
Old 12-12-2006, 04:43 PM
Thought I would try some pattern cutting with some of the multiple parts and looking very good right now. Much faster than the cnc cutting them out.
ID:	27209   Click image for larger version
Old 12-14-2006, 11:12 PM
More parts cut. Pattern cutting is the way to go for me with my setup. Don't know how many more parts I can do this on though.
ID:	27313   Click image for larger version
ID:	27314   Click image for larger version
Old 12-14-2006, 11:37 PM
Moderator
what kind of hold down are you using when cutting these parts?
Old 12-14-2006, 11:46 PM
joecnc2006's Avatar
www.joescnc.com
Looks good so far, how much more do you need for the machine, do you have the HDPE cut also, or just starting out?
Joe
  #12   Ban this user!
Old 12-15-2006, 01:12 AM
David Da Costa is on a distinguished road
Okay I have to ask the obvious question, why are you no longer using your existing router to cut some of the parts?
Template cut part look good though.
David
