12-30-2006, 08:02 AM
| Moderator | | Join Date: May 2006 Location: USA
It looks good though. I'm glad to see saw dust so I know I'm not the only messy one. I actually had to do this assembly outside of my shop because I have too much stuff going on in it right now and don't have the room. Either way I'm hoping to get a majority of it done this weekend. I made a few mistakes already that I don't really slap myself for but know it is going to slow me down. 1 - didn't buy full thread bolts on the longer bolts from bolt depot (reordering this weekend, not a big deal) 2 - put the nuts on the outside (fixed, easy fix actually, just plug, glue, sand bondo and redrill) and 3 getting over zellous and putting both sides on the first torsion box I did without priming inside (the gantry one). I like you stapled them together but was careful because 18 guages were too much for half inch mdf, even at 3/4". It just tears out. But as a cabinetmaker I had to atleast try because staples save a ton of time in cabinet assembly. I think of them like virtual clamps so you can imediately work on something else instead of waiting for glue to set up. Did you see any splitting on your MDF? I also see you used what looks like ply for the skins, any reason? And I like you feel the main torsion box is a bit big for one glue up so I'm going to probably use a slower drying white glue instead of titebond to give me some extra time to finigle with the parts. Either way I'm thoroughly impressed by how clean joes parts are that he sent me. It gives me great hope because I know I can produce the same quality not far off if I finish this build right.
Originally Posted by DougO I don't think it is smaller size motor that is the problem. I use the same Xylotex 269 oz setup that some are using with Joes2006 model and they are getting in the 80 ipm neighborhood. One thing the Sosylva uses 5/16"x18 leadscrews. More threads - slower speed. I think the main thing mine is so slow is me. I don't know enough about the inner works to get the motors working like they are supposed to. I can manually jog around my table @ 40 ipm but when I run a program, the machine stalls out if I go over 15 ipm. I can just be cutting air, do not actually have to be cutting wood. I think if I worked with Mach3 people enough I could get the machine to cut faster. It cuts good with no problems and is very accurate at the 15 ipm speed so that is where I have left it. I have just gotten off on Joes2006 machine and forgotten about the Sosylva.
Have been trying to put some of the torsion boxes together today. I think I got the y-axis, gantry bottom, & x-axis torsion boxes all together except for one on the outer skins. I will leave one side open so I can paint all the insides of the boxes. I needed a couple of extra hands on the x-axis torsion box. It is huge and I tried to glue it up using the 1" pipes that will used in the box. By looking at the picture, I think I could use the x-axis box as a fooseball table( I guess that is how to spell fooseball) if the cnc does not work out. Looked like one to me. Everything is still fitting together and looking right so far.
I ordered the HDPE parts from Joe and got them in today. Everything looked like they were in perfect condition. Maybe I can start putting some paint on some parts tomorrow. | |
