Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > Joes CNC Model 2006
Old 08-16-2006, 05:39 PM
xscsime is on a distinguished road
My Joe 2006 Router
Well I finally got to fire up my new “Joe 2006” and I could not be happier. I started looking at this project some time in Febuary and actually started cutting pieces in March. This is my second router; my first was the Routzilla built from plans from www.crankorgan.com.
I would like to thank Joe for all of his work in the design of this machine as well as thank him for helping me out over the phone. This has been a great project; not only did I build a great machine I also made a friend in the process.
All the parts that would fit in my Routzilla 14.5 X 26 inches I cut using Joes’ DXF files and converting to G code through Turbo Cad /Cam 3. All other parts, the majority, I nested in 4X8 sheets and had them cut locally.
The build was pretty much just as Joe has it drawn. However, I did not put the lightening holes in and instead of half inch 10 TPI acme I used half inch 8 TPI 2 start acme. Substituting the 8TPI 2 start caused me to make a few minor mods to Joes plans and I’ll point those out later on.
For Drivers for the “Joe 2006 I bought the driver kit from (STMD) www.bright.net/~agarb/STMD/AVR_STMD.html . This is a Bipolar driver 3 amps max with chips rated for 55 volts. This was fun to build and Aaron has a top notch kit imho.
My power supply puts out 43.6 volts at 10 amps.
I took a few pictures as I went along and I will try to add them as I go along. I guess this is the backwards way to have a PLOG, but better late than never. More to follow.
Rick
Old 08-17-2006, 07:48 AM
Switcher's Avatar
Moderator
Switcher is on a distinguished road
You might want to send in a photo of your setup!
Check out this link:
http://www.bright.net/~agarb/STMD/User_Gallery.html
Old 08-17-2006, 09:07 PM
Hey thanks for the info, I'll be sure and send him some pictures.
Here are a few pictures of the early stages of the build. The small parts I cut on my Routzilla.
Rick
Name:	Small parts small.jpg‎
ID:	21249   Click image for larger version
Name:	gantry glue up.jpg‎
ID:	21250   Click image for larger version
Name:	small parts 2.jpg‎
Old 08-17-2006, 09:37 PM
More pictures at different stages.
Name:	Primed parts.jpg‎
ID:	21260   Click image for larger version
Name:	Fitting Z Carriage to Y.jpg‎
ID:	21261   Click image for larger version
Name:	Router support on z Gantry.jpg‎
Old 08-18-2006, 12:25 PM
joecnc2006's Avatar
www.joescnc.com
joecnc2006 is on a distinguished road
looks very nice looking forward to seeing more pictures and maybe some parts cut with it, I think you cut some parts at 100in min. with the new machine.
joe
Old 08-18-2006, 08:42 PM
Here are some more pictures of the build.
Because I used the half inch 8 2 start lead screw I had to make my own plastic nuts. I made a tap out of small section of the lead screw and cut the nuts out on my old router. It worked pretty good. The only nuts I could find were around 40 bucks a piece.
I'll show one of the plaques I cut out soon. On my old machine it took me over 1 hour to cut out the design. With the Joe 2006, 20 minutes. That is cutting at 100 inches an minute with rapids at 130. This thing flies!
Name:	Front Shot.jpg‎
ID:	21314   Click image for larger version
Name:	Side Shot.jpg‎
ID:	21315   Click image for larger version
Name:	Side shot with 3ft level.jpg‎
ID:	21316   Click image for larger version
Name:	Plastic nuts.jpg‎
Name:	Plastic nuts 2.jpg‎
ID:	21318   Click image for larger version
Name:	rear anti backlash plus support.jpg‎
Old 08-18-2006, 09:15 PM
monte55 is on a distinguished road
what's that mean
Could someone explain to me what 8tpi 2 start means. I understand 1/2 x 10 tpi but what is the second number plus the word start.
Old 08-18-2006, 09:52 PM
ger21's Avatar
there are 8 threads per inch, but it's two seperate alternating threads (2 start), with each thread being 4 turns per inch. Multi start threads are much more efficient than single start threads, so there's less wasted power.
Old 08-18-2006, 10:31 PM
Gold Member
planescott is on a distinguished road
Your machine looks very nice! How sturdy is it. And also what kind of wood is it made out of.
Scott
Old 09-04-2006, 02:58 PM
joecnc2006's Avatar
www.joescnc.com
Any more pictures, and maybe some work cut on it?
Thanks, Joe
Old 09-04-2006, 09:11 PM
ger21's Avatar
http://www.dumpstercnc.com/leadnuts_acme.html
  #12   Ban this user!
Old 09-11-2006, 12:09 AM
I knew about dumpsters anti backlash nuts. What I was trying to find is actual steel nuts to use per Joes' drawings. I guess I should have made that a little clearer. Thanks though...
Here are a few more pictures.
Name:	Closeup driver board.jpg‎
ID:	22656   Click image for larger version
Name:	Final board.jpg‎
ID:	22657   Click image for larger version
Name:	Final board 2.jpg‎
ID:	22658   Click image for larger version
Name:	long gyro parts.jpg‎
Name:	Long parts 2.jpg‎
ID:	22660   Click image for larger version
Name:	Harley gyro cards.jpg‎
