#61
#62
| “making flats on the galvanized pipe, but only on one side” Is that like a flat tire that in only flat on the bottom? I used black pipe. With a build like this, and so much tension on the pipes, black paint ends up covering the wheels. It didn’t seem to matter that much, but somehow it does not seem like a good thing. I never did sand it off the rails. But even with galvanized, it might be a good idea to sand a smooth track for the bearings. Steve |
#63
| No need to sand them, they are really smooth. The flat is on one pipe, but not the other, and it's very small right now, maybe 1/16" wide. It might just be a softer area on that one pipe.
#64
Joe |
#65
| OK, guess I haven’t worked with galvanized much. Joe, looks like a pretty good Z bearing setup. It would allow someone to use non-precision rod also. You really have gotten good at plastic parts routing. I’m impressed. Steve |
#66
Thanks Steve, I have you, ger21, lionclaw and others here on the zone to thank. It is more than just a hobby now. ![]() I enjoy reading here and also trying to combine ideas into something that works for me. Joe |
#67
#68
| I just took a closer look, and it looks like the one side has worn through the galvanizing. Maybe I will try to turn it when I'm installing the Z-axis. The other side has no signs of wear at all. Must be a bad spot on the EMT. I have a panel saw Which uses a similar bearing setup on the same size EMT, and it hasn't worn through with over 10 years of use, but the load is much lighter.
#71
