Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > Joes CNC Model 2006
  #13   Ban this user!
Old 11-26-2005, 11:31 AM
acondit's Avatar
acondit is on a distinguished road
Joe,
At the rate your going, maybe you should have named it "CNC Model 2006". It looks great so far.
Alan
Old 11-26-2005, 06:43 PM
joecnc2006's Avatar
www.joescnc.com
joecnc2006 is on a distinguished road
Originally Posted by acondit
Joe,
Alan
Well Hope to get it finished real soon....
Old 11-26-2005, 06:45 PM
joecnc2006's Avatar
www.joescnc.com
Gantry Upper Torsion Box...
Name:	Gantry Top Torsion Box 1.JPG‎
ID:	12313   Click image for larger version
Name:	Gantry Top Torsion Box 2.JPG‎
Old 11-26-2005, 06:46 PM
joecnc2006's Avatar
www.joescnc.com
Motor and Leadscrew Bearing Mounting plates, which will hold the Pipe rails also...
Name:	Motor and Leadscrew mount plates.JPG‎
Old 11-27-2005, 01:29 AM
joecnc2006's Avatar
www.joescnc.com
Gantry Lower Torsion Box and Gantry Rt Side.....
Name:	Gantry Lower Torsion Box.JPG‎
ID:	12321   Click image for larger version
Name:	Gantry Rt Side.JPG‎
  #18   Ban this user!
Old 11-27-2005, 05:04 PM
sdantonio's Avatar
sdantonio is on a distinguished road
Joe,
while you posting can you throw out some of the dimensions your using, like pipe spacing for the long y-axis runs. Any other dimensions would be great too. What would really be great if it wouldn't be to much trouble would be to post your drawings for the pieces as you build them like the gantry rib parts etc.
I'm thinking of trying to build the same type of machine as you go along. The main difference is that I'm looking at a 31 x x48 cutting area, and I'm going with plywood which I think would be a bit stronger in the long run.
Steven
Old 11-27-2005, 07:11 PM
joecnc2006's Avatar
www.joescnc.com
Originally Posted by sdantonio
Joe,
Steven
This machine is using the 1" x 60" Gas Pipe (Y Axis) 4"o.c., 3/4" x 36" Gaspipes (you could just extend it out the 12" width on the X Axis But Will add more weight, just add another motor and slave it on the Y-Axis to move the gantry.
Which Gives me an Idea and Possibly a question to pose can you slave two motors, such as Y-Axis and another A-Axis and place them on each end of one Lead screw But Just Reverse the A-Axis Motor I would think this would double your torge???
Joe
Old 11-27-2005, 07:15 PM
joecnc2006's Avatar
www.joescnc.com
I had already recieved my 1/2" inside dia. bearings for the acme 1/2-10 leadscrews i ordered. (you could use 1/2"-13 standard thread also but I want to maximize speed), So i drew up a Leadscrew Bearing Support which has same bolt pattern as the Nema 23 motors.
Name:	0.5in Bearing Support.JPG‎
Old 11-27-2005, 11:28 PM
joecnc2006's Avatar
www.joescnc.com
Well I got tiered of using a wrench and nut to clamp down my parts so I made a few of these, Knobs like that with 1/4" thread inside are almost $3.00 at the hardware store (must be proud of them or something) so i made a few of my own.
Here is a picture of some and also the g-code if people want to make their own, (.25 end mill 3/4" stock) Rename the *.Zip ext. to *.Tap can not upload the file otherwise.
Name:	.25 Hold down clamp screw.JPG‎
Old 11-28-2005, 10:47 PM
joecnc2006's Avatar
www.joescnc.com
Got the Z Axis Carriage done, I think i pushed my HP motors to their limit, I cut these at 40ipm with no problem.
Name:	Z Axis Carriage Sides.JPG‎
Old 11-30-2005, 12:08 AM
joecnc2006's Avatar
www.joescnc.com
Z Axis Carriage assembled, will have 4 - 1/4" threaded rod through sides, top and bottom to make sure the pressure of the bearings on rails do not start to push assembly apart.
Name:	Z Axis Carriage 1.JPG‎
Old 11-30-2005, 11:31 PM
joecnc2006's Avatar
www.joescnc.com
I got my 1/2"-10 acme threaded rods, and my 36" drill rods (i cut them to the proper lenght)
I desided to use the same type of Anti-backlash nuts I made for the 5/16" rod and nuts.. so here is its big brother....
Name:	anti-backlash nuts.JPG‎
