Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > Joes CNC Model 2006
  #1729   Ban this user!
Old 11-13-2011, 11:32 PM
arudson is on a distinguished road
Thanks Don. I think I now understand the meaning of 'start'. Is there a general opinion of what the best lead screw start arrangement is? The guide calls for Acme 1/2” – 10 but I see references to Derhlin anti-backlash assembly and other screw sizes and starts. I’m confused what replaces what and how this all ties together.
I am trying to put together my complete shopping list of hardware and note that the construction assemble and hardware listing calls for 3 each of 1/4” Bore LoveJoy Coupler, Keyway Spider and 1/2” Bore LoveJoy Coupler. This doesn’t seem right to me unless one 1/4” and 1/2” are used on and each of the x, y and z axis.
I apologize if this is simple stuff but I’m just not getting it. Any help would be very much appreciated.
Alan
  #1730   Ban this user!
Old 11-14-2011, 07:37 AM
atwooddon is on a distinguished road
Alan, the list is correct. You need 3 each of the 2 sizes. One size fits over the end of the lead screw (1/2") and one size fits over the shaft of the stepper motor (1/4")
Don
  #1731   Ban this user!
Old 11-14-2011, 07:55 AM
cutter100's Avatar
cutter100 is on a distinguished road
Hi Alan, Also one of your questions was about 2 start and 5 start screws. If you look at the end of a threaded rod you'll see the begining (start) of where the nut threads on to the bolt/rod. On a 5 start there's 5 begining points. Makes for a much tighter and faster spin. I bought mine 6 months ago from Kent and he had upgraded it to 5 start. If you go this route there is a different calc you do in motor tuning. If I remember correctly it's 3200
Hope I explained that right.
Chris
Chris.....Everyday is a Good day.....if you wake up breathing!
Joe's 2006, Mach3, Vectric software.
