Results 1 to 6 of 6
Thread: Heavy spindle problem !!!
    Nov 2005
    Hi guys ,
    I've just completed the replacement of my old Porter cable router for a water cooled 2.2Kw spindle . It works great , BUT, i did not expect that it would be a lot more heavier for the z axis !! for now reducing the rapids on the z axis solved the missing steps . But would like to keep the speed i add. so
    What i would like to know, is there any of you that setup something to counter weight a spindle, any idea?? , springs, bungee cords !!!
    Jan 2008
    springs work on the shopbots you just need to know how much you will need to balance you spindle.
    Apr 2004
    Oakland CA USA
    You might think about mounting a gas spring on your Z axis. I've tried other things, but that seems like the best alternative.
    Andrew Werby
    ComputerSculpture.com — Home Page for Discount Hardware & Software
    Registered bonmotwang's Avatar
    Feb 2011
    The acceleration settings may simply solve your problem.
    Nov 2005
    Quote Originally Posted by bonmotwang View Post
    Tried ,but no luck , reducing the top speed did , because it is only happening with rapid move !!
    I'm gonna try the spring way !!!
    Nov 2005
    Just welded and installed a bracket to support the spring !! set it up for a zero weight spindle when my longest tool touch the table !!!
    my Z axis is now flying as it never did before !!!! oh yeahhhhhhhhh
    1. Gantry too heavy?
      By erikjgreen in forum DIY CNC Router Table Machines
      Last Post: 07-07-2011, 11:35 AM
    2. Heavy 2X4 Router
      By gd.marsh in forum DIY CNC Router Table Machines
      Last Post: 11-17-2010, 07:35 PM
    3. Heavy Duty DC Servo Spindle Drives.
      By Al_The_Man in forum Stepper Motors and Drives
      Last Post: 06-02-2009, 04:10 PM
    4. Heavy is good???
      By zaebis in forum Syil Products
      Last Post: 05-28-2009, 08:17 AM
    5. heavy gantry
      By drafterman in forum JGRO Router Table Design
      Last Post: 11-07-2007, 11:59 AM
