Originally Posted by
Go-Go-Legoman
Hi all I'm studying the Joe 2006 R2 easm file and I'm looking for some clarification on the adjustable bearing slides.
To use the Y axis as an example, I see that the top slide is bolted to an HDPE block. The HDPE block does not appear to be bolted to the Z-axis carriage but is instead press-fitted into the carriage top. The tight fit should offer enough friction to prevent the HDPE block from wobbling but on the flip-side, that friction would probably make it difficult to adjust tension with the four 5/16 2" bolts. Is there something that I'm missing?
