Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > Joes CNC Model 2006
Old 11-04-2011, 09:02 PM
wouldlike2no is on a distinguished road
Angle and v groove rollers
Regarding Joe's 4 x 4 Hybrid...
What is the metal spec for the L angle? Is the angle susposed to have a square edge or a rounded edge to track the v groove rollers? Or, does it make a difference?
What is Joe's spec for the V groove BB rollers? Is VDX the best place to purchase these?
I searched the VDX website and was unable to determine the the actual size of the V groove. I would like to use the rollers on 3/16" square edge aluminum. Anyone see problems doing this.
Thanks for your consideration.
Old 11-04-2011, 09:25 PM
Walky's Avatar
Walky is on a distinguished road
Just take "C" (thickness) value from the VXB product page and divide it by 2, the result should be a very close value to the groove width.
By "edge" do you mean the ends of the "L", or is it the center of the angle you're talking about?
V-groove bearings and aluminium angle Yvan256 Linear and Rotary Motion 3 08-15-2011 11:38 PM
New Machine Build- The Bottom Line on V Groove and Angle. dmiller47591 DIY-CNC Router Table Machines 9 01-06-2011 06:49 AM
Read if looking for V-Groove rollers Spiral_72 Mechanical Calculations/Engineering Design 18 05-27-2009 03:11 PM
"Home-made" V-groove rollers and rails Gerald_D Linear and Rotary Motion 10 06-14-2008 02:02 AM
Has anyone used crown rollers? jerchi DIY-CNC Router Table Machines 1 10-19-2007 08:54 AM
