Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > Joes CNC Model 2006
Old 10-12-2011, 09:34 PM
Dustoff10 is on a distinguished road
X - axis very jerky
Need some help on newly finished Joe's 2006.
Everything appears to be running fine using Mach3, 305 oz stepper motors, HobbyCNC pro driver, but!
The x axis has a real whipping problem and a significant stutter when jogging anywhere above 35 ipm. I am using the standard 1/2 10 acme rods with the standard acme nuts configuration but with the spring between the nuts to help prevent backlash. I have also mounted springs on the acme rod ends as suggested in the forum to further correct whipping.
Can the improper tuning of the motors do this?
Any help would be greatly appreciated
Old 10-12-2011, 10:48 PM
atwooddon is on a distinguished road
Could you be running into a resonance problem? The combination of whipping and/or resonance could probably cause jerkiness.
Don
Old 10-13-2011, 08:44 AM
Resonance
Thanks for the reply,
If this is the case, how do I overcome resonance on this axis?
Bill
Old 10-13-2011, 09:12 AM
Bill, here are a couple threads discussing resonance and the simple fixes.
http://www.cnczone.com/forums/steppe...er_damper.html
http://cnczone.com/forums/stepper_motors_drives/100381-$1_50_per_axis_dirt.html
The whipping is not going to be fixed with the resonance dampers so you need to solve that seperately.
Don
jerky moves stoj Videos 11 10-22-2011 12:33 PM
Radial rapid moves around axis are jerky surfsup Fanuc 4 09-13-2011 02:39 PM
Jerky motion Matty Zee G-REX 9 03-28-2010 02:35 AM
Jerky Y axis beamsjr Joes CNC Model 2006 6 03-07-2010 08:57 PM
Jerky Z axis???? bill south Benchtop Machines 7 09-10-2006 09:33 AM
