Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > Joes CNC Model 2006
Old 12-09-2010, 06:31 PM
Ezra is on a distinguished road
Touch Sensor Z Axis?
Hi Guys,
Is there a touch sensor that I can put between my bit and the Corian Im carving in too. Ive been using a feeler gauge and have been going back-n-forth as I lower the Z-axis, somewhat time consuming.
Something mechanical, not interested in hooking it up to a computer.
Thank You
Old 12-09-2010, 07:01 PM
CarveOne is on a distinguished road
Originally Posted by Ezra View Post
Hi Guys,
Thank You
There are LED and dial gauge types of zero setters available. You just lower the Z axis at a slow rate until the LED lights up or the dial just starts to move. The link above shows both styles.
CarveOne
CarveOne
Resistance is not futile. It is voltage divided by current (R=V/I).
jalessi's Avatar
jalessi is on a distinguished road
Post
Ezra,
Edge Technology Products makes a nice tool setter for about $60.00
Pro Touch Off Gage
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Old 12-09-2010, 07:04 PM
jalessi's Avatar
There is a import on eBay for $30.00
Dial Z Axis Setter Brand New - eBay (item 140487595116 end time Dec-14-10 00:14:35 PST)
Old 12-14-2010, 02:03 PM
CNC-Joe is on a distinguished road
Ezra,
I know you didn't want to do anything with electronics - but if you see how easy it is to do this - and how well it works (not to mention inexpensive)...
Check out Greolt's link (there are others too)
http://www.cnczone.com/forums/cnc_wo...ro_setter.html
Cheap, easy, precision- at its best.
JoeComunale (at) Comcast.Net
CNC Is Not Just My Passion.. It's My Addiction !!!!
Need Help!- J325 Z axis proximity sensor ??? lavrgs Tree 10 08-31-2009 10:36 AM
Z-Axis depth guide sensor ? deleteallusers Mechanical Calculations/Engineering Design 5 07-17-2007 12:38 AM
DIY pressure sensor ? - Touch Off Plate ? deleteallusers Mechanical Calculations/Engineering Design 4 06-22-2007 04:56 PM
Tool Height Touch Sensor for Techno-Isel mikkojay DIY-CNC Router Table Machines 8 08-08-2006 02:28 PM
lathe tool eye or touch sensor Karl_T CamSoft Products 2 04-26-2006 06:15 AM
