Results 1 to 3 of 3
Thread: Simple yes/no question about Joe's 4x4
    Apr 2009
    Doing a lot of research for my next build. The designs I am considering are the MechMate and the Joe's 4x4 Hybrid. Both use v-groove bearings on angle iron rails. The MechMate uses larger bearings than Joe's 4x4 and thicker (1/4") angle iron. The rails are ground to match the v shape of the bearings.
    Are the rails in Joe's 4x4 ground to fit the bearings?
    Mar 2003
    Shelby Twp, MI....USA
    No.
    At least not normally. But I think I read recently that some have ground them ala Mechmate.
    Jun 2005
    No. Central CA, USA
    I tried grinding the edges of my angle iron on my Joe's 4X4 and it was a noisy and bothersome waste of time. I ended up filing the angle on the edges - only took about 5 minutes per 6-foot piece. Since I plan to use my machine primarily for wood and acrylics, v-bearings on the angle iron will definitely produce the tolerances I'll need.
  1. just a simple question
    By chrispare in forum Hobbycnc (Products)
    Last Post: 03-10-2010, 08:47 PM
  2. Joe's 2006 Question on size of cutters machine will handle??
    By Rooney in forum Joes CNC Model 2006
    Last Post: 11-19-2009, 11:55 AM
  3. just one simple question..
    By nascarstewartfa in forum General Waterjet
    Last Post: 10-30-2008, 03:43 PM
  4. Simple Question Simple Answer ?
    By p3t3rv in forum Stepper Motors and Drives
    Last Post: 02-16-2006, 10:00 AM
  5. Simple question?
    By johnney0005 in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 03-26-2005, 11:52 AM
