Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > Joes CNC Model 2006
Old 09-13-2010, 02:00 PM
nego_0 is on a distinguished road
Mach 3 G540 Pci card.
I've searched and searched. What is a good PCI / PCIE Parallel port card for the g540 and Mach 3? I've tested my hardware on an old pc, and all went well. But i am unable to find a good PCI EPP parallel port card for a machine without parallel on the motherboard.
Old 09-13-2010, 04:53 PM
http://www.siig.com/ViewProduct.aspx?pn=JJ-P01211-S6 Its the only one i found to work with Win 7 64 bit and all other O/S's what dose the community think.
Old 09-13-2010, 05:20 PM
Torchhead is on a distinguished road
If you are running XP any card with a NETMOS chipset works with MACH. There are cheap ones at
http://www.newegg.com/Product/Produc...llel+port+card
If you are a "Pioneer" and using Windows 7 then it's not going to be as easy. Most cards don't have drivers yet and those that do I wouldn't trust them.
I have two customers now trying to get ports installed in Windows 7 machines with no luck.
TOM caudle
www.CandCNC.com
Old 09-13-2010, 07:38 PM
ger21's Avatar
You can't use the parallel port for step direction with a 64 bit OS.
Old 09-13-2010, 08:27 PM
Is there a reason why?. Is it do to the way bits are flipped in the 64bit os?
Old 09-13-2010, 08:49 PM
ger21's Avatar
Mach3's driver is 32 bit, and won't run on a 64bit OS.
Old 09-14-2010, 04:22 AM
OH! ok then its back to running xp on a small rig then. I have not seen anything to make me think there will be an update to a 64bit os, so xp here we go! thanks for the replies evryone. I am shocked that a 10$ card works with charge pump.
Old 09-14-2010, 10:50 AM
ger21's Avatar
You can use 32 bit Windows 7.
Old 09-15-2010, 05:13 AM
I do have win 7 32 around some place. i think the best route at this point is to run 2 OS or have 2 machines. Im tinkering with the idea of building a lcd in a stand with all of the cnc and computer componeents in one small box
Old 10-09-2010, 09:45 PM
Ezra is on a distinguished road
Are you guys talking about "Genuine Windows 7 Home Premium, 64bit, English"?
I just got a quote today from Dell for the computer I want to buy to operate my Joes 2006.
If you are talking about the above, should I contact them and tell them I want the 32 version?
Thank You
  #11   Ban this user!
Old 10-09-2010, 10:39 PM
It's your money, but for about $125.00 you can get a refurbished Dell with 3GHZ processor, 1G ram, internal parallel port and XP Pro loaded and ready to run. If you run the PC as suggested as a dedicated controller, optimized, and just running MACH3, that is plenty of horse power. Pretend you are buying a CNC controller not a PC,
Ebay auction ID # 170532955611
Then you can buy your whiz-bang 64 bit, killer PC to do your CAD and CAM work on (or not and save several hundred bucks!)
MACH will NOT run in Windows 64 bit version.
TOM caudle
www.CandCNC.com
  #12   Ban this user!
Old 10-09-2010, 10:50 PM
Torchhead,
Thank you!!! I looked at that auction. Do you see anything with that auction that would contradict with the :
Mach3 Minimum Requirements:
32-bit version of Windows 2000, Windows XP, Windows Vista, or Windows 7 Operating System
1Ghz CPU
512MB RAM
Non-integrated Video Card with 32MB RAM
Basic Computer Skills (ability to copy/rename files, browse directories, etc)
Desktop PC (if using the Mach3 Parallel Port Driver - laptops are not supported because the power saving features of the chipsets disrupt the pulse stream, PCMCIA and USB parallel adaptors will *not* work.)
Thanks!!!
Need Help!- Anybody have a working PCI parallel card for G540 w/ charge pump enabled? Jr's Farm Gecko Drives 27 04-16-2011 01:23 PM
Need Help!- Servo Drive Card for Mach II / Mach III umarcnc Mach Mill 2 02-21-2010 02:37 AM
Need Help!- G540 and C3 index pulse card cmanning Gecko Drives 5 02-12-2010 07:09 AM
Need Help!- G540 and C3 index pulse card cmanning G-REX 1 06-30-2009 02:46 PM
