Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > Joes CNC Model 2006
Old 08-20-2010, 10:29 PM
trimbandit is on a distinguished road
Joe's 2006...problem with 200oz steppers
So after 4 years we finally got the cnc together...what can I say I got distracted by other things.
Anyway, we are running tests in mach using the hobbycnc pro board and the 200oz steppers. We have tried 1/2 step and 1/8 step and 60ipm works fine, but it stalls at 80ipm on all axis. This is not cutting, but just jogging around to test.
Wondering if we might have mach set up wrong or if this is just a limitation of the 200oz motors. I was thinking we would be able to move around at 120 and cut at 80. Is that unreasonable?
Any help appreciated.
Thanks!
Craig
Old 08-22-2010, 10:36 AM
AJ Negvesky's Avatar
AJ Negvesky is on a distinguished road
questions
Just a couple of questions
1.) What controller software are you using?
2.) What lead screw are you using? 1 2 or 5 start
Old 08-22-2010, 11:53 AM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
Hi Craig. Nice first post--finally! Welcome to the Zone!
You are actually getting pretty good speed for a unipolar driver. If you are not using a 36V PSU, then going to that may help some. How long and thick are your screws? Screw whip can lessen speeds. Using multi-start screws may help. You could make and install hocky puck anti-resonance dampners.
If screw whip is not a problem, and if you ARE using a 36V PSU, then this should at least double your speeds:
1. Bite the bullet, spend the $249 and upgrade to G540.
2. Wire those motors bipolar parallel, and use 3.48K resistors. They are 4.2A motors and will detune to 237oz--Still more than what you have now.
With G540 and your present motors, you could also upgrade to $60 Keling 7.3A, 48V PSU for even more speed. For max performance with G540, you could replace the 200oz motors with $50 each Keling 381s.
CR.
http://crevicereamer.com
Too many PMs. Email me to my name plus At A O L dot com.
Old 08-22-2010, 12:07 PM
ger21's Avatar
I can get 190ipm on a larger machine than the 2006 with a Xylotex and 250oz steppers with 1/2-8 2 start acme screws.
Give us a little more info on your screws and power supply.
Old 08-22-2010, 01:35 PM
I appreciate the responses.
1. I am using Mach3
2. Screws are 1/2"-10 Acme leadscrew(enco #408-0220). There is whip on the longest screw which is probably 5 feet. I was not sure how much to tighten it. It feels pretty floppy even at rest. However, I have the same stall outs on the short Z screw which does not seem to whip.I believe the screws are single start
3. I am using this driver board package. It runs at 34VDC
It doesn't feel like anything is binding. I can turn the screws with minimal finger pressure.
Cheers,
Craig
Old 08-22-2010, 01:53 PM
ger21's Avatar
So, at 80 ipm, you're getting 800rpm. At 190ipm, I'm spinning my screws at 760rpm.
So, it sounds like your screws are the limiting factor, even though your motors are on the small side.
There are plenty of people getting much faster speeds with a HobbyCNC motor, but they're using different screws and usually bigger motors.
A cheaper option than getting a G540 and different motors would be to get 1/2-8 2 start screws. You may still want larger motors, but the screws alone will give you more speed.
As for the Z axis, does it sound rough? If so, you might be getting resonance. If so, you can make dampers that can possibly help. But you'll need dual shaft steppers to mount them. They made a tremendous difference on my machine.
http://www.cnczone.com/forums/showpo...&postcount=180
Old 08-22-2010, 07:21 PM
ianober is on a distinguished road
I think the lead screws being the issue sound about right Craig. All axis' stall out at the same rate no matter how long or short they are, but we definitely are getting some whip on the Y axis that is causing vibration. We may want to think about different lead screws if you want the higher speeds.
Old 08-23-2010, 04:35 PM
Thanks guys. I will try the 2 start screws as a first step.
Old 08-23-2010, 04:51 PM
Edit: Holy crap $233 shipped for 12 feet of screw and all the nuts. Maybe I will stick to slow speeds.
Old 08-23-2010, 06:50 PM
ger21's Avatar
How about $7.31/ft and $19.50 per nut?
http://www.roton.com/Mating_Componen...family=7060404
http://www.dumpstercnc.com/
When I bought mine 7 years ago, they were $26 for 6 ft.
  #11   Ban this user!
Old 08-24-2010, 06:21 PM
Thank you! I am going to go ahead and order the 2 start.
  #12   Ban this user!
Old 08-24-2010, 07:17 PM
Yeah baby!!!!!
New Machine Build- Going to Try Again...With a Joe's 2006 emtffkev Joes CNC Model 2006 3 09-27-2009 02:42 PM
Newbie- Joe's 2006 Prebuild mrlenny Joes CNC Model 2006 15 08-12-2009 02:38 AM
Difference between Joe's 2006 R1 and R2 ? newsense2004 Joes CNC Model 2006 2 08-10-2009 10:55 PM
Joe's 2006 in Philadelphia PhillyCyberJoe Joes CNC Model 2006 81 12-23-2007 01:13 PM
Joe's 2006 in OH fade2black Joes CNC Model 2006 44 07-18-2007 08:46 PM
