How to setup this Mod bus Interface to mach3,and the schematic where is step,direction output.. http://www.fieldofcows.com/index.php...dbus_Interface ![]() ![]() ![]() /*!--------------------------------------------------------------------------- ** @file main.c ** ** @brief Firmware main file for USB Modbus I/O Interface ** **--------------------------------------------------------------------------- ** ** ** This file is part of the firmware for the Field of Cows USB Modbus I/O ** project (USBModbus) ** ** USBModbus is free software: you can redistribute it and/or modify ** it under the terms of the GNU General Public License as published by ** the Free Software Foundation, either version 3 of the License, or ** (at your option) any later version. ** ** USBModbus is distributed in the hope that it will be useful, ** but WITHOUT ANY WARRANTY; without even the implied warranty of ** MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the ** GNU General Public License for more details. ** ** You should have received a copy of the GNU General Public License ** along with USBModbus. If not, see <http://www.gnu.org/licenses/>. ** */ /*--------------------------------------------------------------------------- ** Includes */ #include <p18f4550.h> #include <portb.h> #include "usb_config.h" #include "USB/usb.h" #include "USB/usb_function_cdc.h" #include "USB/usb_device.h" #include "modbus.h" /*--------------------------------------------------------------------------- ** Defines and Macros */ #pragma config PLLDIV = 5 // (20 MHz crystal) #pragma config CPUDIV = OSC1_PLL2 #pragma config USBDIV = 2 // Clock source from 96MHz PLL/2 #pragma config FOSC = HSPLL_HS #pragma config FCMEN = OFF #pragma config IESO = OFF #pragma config PWRT = OFF #pragma config BOR = ON #pragma config BORV = 3 #pragma config VREGEN = ON // USB Voltage Regulator #pragma config WDT = OFF #pragma config WDTPS = 32768 #pragma config MCLRE = ON #pragma config LPT1OSC = OFF #pragma config PBADEN = OFF #pragma config STVREN = ON #pragma config LVP = OFF #pragma config XINST = OFF // Extended Instruction Set #pragma config CP0 = OFF #pragma config CP1 = OFF #pragma config CPB = OFF #pragma config WRT0 = OFF #pragma config WRT1 = OFF #pragma config WRTB = OFF // Boot Block Write Protection #pragma config WRTC = OFF #pragma config EBTR0 = OFF #pragma config EBTR1 = OFF #pragma config EBTRB = OFF #define CLOCK_FREQ 48000000 #define GetSystemClock() (CLOCK_FREQ) /*--------------------------------------------------------------------------- ** Typedefs */ /*--------------------------------------------------------------------------- ** Local function prototypes */ void handle_high_isr(void); void handle_low_isr(void); /*--------------------------------------------------------------------------- ** Data */ /*--------------------------------------------------------------------------- ** Interrupt vectors and handlers */ // // Define the high priority interrupt vector jump at address 0x08 // #pragma code HIGH_INTERRUPT_VECTOR = 0x08 void high_isr( void ) { // The code here is in a vector table so we have only got a few // bytes to play with. Therefore just jump to the isr _asm goto handle_high_isr _endasm } // // Define the low priority interrupt vector jump at address 0x18 // #pragma code LOW_INTERRUPT_VECTOR = 0x18 void low_isr( void ) { _asm goto handle_low_isr _endasm } #pragma code // // The vector jump for the high priority interrupt jumps // to this function. The #pragma interrupt ensures that // the correct return is generated from the function // #pragma interrupt handle_high_isr void handle_high_isr( void ) { // Handle any pending USB tasks USBDeviceTasks(); } // // The vector jump for the low priority interrupt jumps // to this function. The #pragma interruptlow ensures that // the correct return is generated from the function // #pragma interruptlow handle_low_isr void handle_low_isr( void ) { } //-------------------------------------------------------------------------- /*! ** @brief Main firmware process entry point ** */ void main(void) { unsigned char count = 0; // Initialise the USB library USBDeviceInit(); USBDeviceAttach(); // Initialise the Modbus routines #ifdef MODECONTROL_SW setMode(MODE_RTU); #endif initialiseModbus(); // Enter the main processing loop while (1) { if ((USBDeviceState >= CONFIGURED_STATE) && (USBSuspendControl != 1)) { processModbus(); CDCTxService(); } } } //-------------------------------------------------------------------------- /*! ** @brief Handler that is called when the host sets the baud rate for ** the CDC connection ** ** This function gets called when a SetLineCoding command ** is sent on the bus. This function will evaluate the request ** and determine if the application should update the baudrate ** or not. ** */ void set_line_coding_handler( void ) { //If the request is not in a valid range if (cdc_notice.GetLineCoding.dwDTERate.Val > 115200) { // Stalling the endpoint is the correct thing to do in this // case but it can cause the host application to crash if it // doesn't handle this properly. If that is the case then // the line below can be commented-out USBStallEndpoint(0, 1); } else { DWORD_VAL baud; // Update the baudrate info in the CDC driver CDCSetBaudRate(cdc_notice.GetLineCoding.dwDTERate.Val); // Update the baudrate of the UART baud.Val = (GetSystemClock() / 4) / line_coding.dwDTERate.Val - 1; SPBRG = baud.v[0]; SPBRGH = baud.v[1]; } } //-------------------------------------------------------------------------- /*! ** @brief USB event callback ** ** @return TRUE ** ** This function is called from the USB stack to ** notify a user application that a USB event ** occured. This callback is in interrupt context ** ** @param[in] event Type of event ** @param[in] pdata Pointer to event data ** @param[in] size Size of event data */ BOOL USER_USB_CALLBACK_EVENT_HANDLER( USB_EVENT event, void *pdata, WORD size ) { // We just forward these events to the relevant CDC handler switch (event) { case EVENT_CONFIGURED: CDCInitEP(); break; case EVENT_EP0_REQUEST: USBCheckCDCRequest(); break; case EVENT_TRANSFER: Nop(); break; default: break; } return TRUE; } |
| Mach3 Diy Pendant Schematic | xlukkajr | Mach Wizards, Macros, & Addons | 3 | 02-17-2012 09:34 AM |
| Looking For A Job- MODBUS I/O Controller for Mach3 (MBIO)! | icm | Product Announcements & Manufacturer News | 0 | 05-20-2009 11:54 AM |
| Is there an easy dc-dc step-up schematic? | Gyvven | General Electronics Discussion | 10 | 01-24-2009 10:02 AM |
| Mach3 with Hitachi VFD using Modbus | swinn | Mach Software (ArtSoft software) | 2 | 11-28-2008 12:44 PM |
| Other controllers that output step/direction? | cn00728 | General Electronics Discussion | 3 | 02-02-2005 01:30 PM |
