I would like to build such a machine. My question would be, how reliable and accurate? Especially I would like to bite her trees, musical instruments and make my job easier I would like.
Hi, I can't download your zip file, please help
thanks
Pat,
Hi!
I was wondering if it's possible to replace the HDPE with acrylic? HDPE is extremelly expensive in my country.
Some have done it but the acrylic can be brittle. I had made some of my hybrid out of acrylic and it worked.
Thanks,
Joe
www.joescnc.com
joecnc2006 at yahoo
Hey Joe, thanks for the reply!!
What about high molecular weight polyethylene (HMWPE)?
Thanks a lot!
You may want to look at the tensile strength, I think it may be lower than HDPE but in this application may be just fine. Also I believe that some of those materials is oil impregnated for self lubrication so this would have to be taken into consideration then using washers, surface contact areas etc, there may not be good friction to avoid loosening, may need to switch to locking nuts in places. there is allot of vibrations when cutting various materials. which can over time loosen bolts (which should be check periodically anyway).
Thanks,
Joe
www.joescnc.com
joecnc2006 at yahoo
Thanks a lot Joe, luckily I was able to find a piece of HDPE
Regards!
good to hear.
Thanks,
Joe
www.joescnc.com
joecnc2006 at yahoo
Hey guys, just a stupid question, how do you prevent the bed from being cut?
For instance if I use a bed like this with rails (I am planning to use one like that to clamp the piece to cut)?
I have red that you can limit the Z axis depth, but only one mm mistake and the bed is scratched.
Sorry again for the silly question.
Regards!
He will probably glue aspoil board on top of that and then when it gets worn resurface it many times, then when it gets to low, resurface then add another spoil board on top and do a final surface.
Thanks,
Joe
www.joescnc.com
joecnc2006 at yahoo
Ah, little detail I didn't know about the spoil board.
Sorry I will be asking more dumb questions,
1) What is the purpose of the X axis bearing adj plates? Why is it in one side and not in both?
2) Why are the holes in magenta (1/4") and blue (1/5") (see image) of different diameters? Should't they be the same as the same screw goes through them (1/4")? Won't it damage the MDF or HDPE piece as the hole is smaller than the screw?
the ones in blue look like they are for tapping 1/4" to it should be around 0.19", Also the antibacklash nut housing is only for acme nuts if you are using them, if you ate using dumpster delron nuts you do not need them.
Thanks,
Joe
www.joescnc.com
joecnc2006 at yahoo
As far as I know you do the final pass with a very small tool or you can use a sharp chisel
Every time I try to download the viewer I am told that I need a full subscription?????
I am using a Windows PC not a mobile device.
That's what I do. Use a 1/8" bit and drill holes in the corners for clearance.If it's to take a hex head, you could also put circles (maybe pre-drill?) the corners so the sharp edges fit in.
UCCNC 2017 Screenset
