Mitch's Evolution Machine making first movements.
Here is a pretty cool folding Base Design Jason Made, His "Joe's CNC Evolution" is a 5x10 machine.
Thanks,
Joe
www.joescnc.com
joecnc2006 at yahoo
Thanks,
Joe
www.joescnc.com
joecnc2006 at yahoo
I've emailed joe about this but will post the question here too...
I just ended a bad relationship with a CNC kit sold by another individual online. Bought it for using Vectric's V Carve Pro and Adpire carving software. I have a lot invested in it but turns out I have to scrap it. The gantry sags and this ruins the carvings. Nothing that can be done other than to haul it to the dump.
The plan now is to salvage what I can (like the 2.2 kw spindle) and hopefully find another kit that's built better. Is the gantry on the hybrid 4x4 stiff enough to support my spindle w/o drooping? The current machines gantry droops nearly .075".
I read good things about joes machines here and on other forums, but after getting burned to the tune of over $3k on the current machine I'm just being cautious.
Thanks for any help.
The Evolution machine used a 3"x6" beam and several of my members use the water cooled spindle the beam will work very well with what you have.
One questions what are your motors and electronics, psu included with amps.
Thanks,
Joe
www.joescnc.com
joecnc2006 at yahoo
I have 3 each 425 oz nema 23 motors, 3 each cw230 drivers, a 30 amp pwr supply, PC w/ mach 3.
425oz motors will work fine I have used those unipolar motor wired to bi-polar on my original hybrid machine. You will however need another motor and driver as the machine uses 2 motors on the Y-Axis to drive the gantry from both sides, this increases the power to move the gantry, i.e. each motor only moving 1/2 the weight. we just simply slave the axis in mach3 or EMC.
On the PSU 30 amp is more than enough, I would make sure you use 36v or above, 48v is better of course.
Thanks,
Joe
www.joescnc.com
joecnc2006 at yahoo
I think your drivers may be limited to 36v max. so a 36v PSU will work.
Thanks,
Joe
www.joescnc.com
joecnc2006 at yahoo
I can scrounge another motor and driver and yes the cw230 have 36 volt limits.
I've e-mailed asking Joe this, but maybe others who've built the Evo 1.0 could weigh in too. What types of more significant tools or machinery are necessary for this build? I'm not looking for sepecifics, but a good general idea to see if this is feasible with the tools I have access too. I know this may be a tough question due to the many ways or different options of building, but any help would be appreciated.
Tools I currently have:
Miter Saw
Reciprocating Saw
Hand Drill
Drill Press
Common Small Tools (Wrenches/Screw Drivers/etc..)
you should have received and email yesterday. let me know.
Thanks,
Joe
www.joescnc.com
joecnc2006 at yahoo
Thank you Joe, I most certainly received your e-mail. I unfortunately don't have a welder, so looks like I'll have to come up with some wooden table. I've just purchased the plans and once activated, I'll be rummaging through the forums to get a game plan together.
Got the plans and they look great! Can't wait to see the Evo changes on the forums. I'm also hoping to get a lot of good ideas on the tables from the forums. Thanks again Joe!
Hello everybody
This is my first post here and my first step towards building a CNC machine. I hope to learn here and build a CNC machine.
First what is difference between Joes 4x4 Hybrid and Joes Evolution.
Apart from Machine Hardware, what electronics will be involved.
Jason's 5x12 Evolution machine built and now Cutting "Joe's Snap E-Chain" for itself.
Thanks,
Joe
www.joescnc.com
joecnc2006 at yahoo
Has anyone milled aluminum with the Evolution yet? How deep of cuts? How much gantry flex?
Thanks,
Jerry
Boise
Yes i cut the evolution kits on mine. 3/4" plate aluminum that people are
using to build theirs.
Thanks,
Joe
www.joescnc.com
joecnc2006 at yahoo
Rich, almost has his machine finished, I think there is about 75-80 of the Evolution's built now.
Thanks,
Joe
www.joescnc.com
joecnc2006 at yahoo
Its been a little while since I posted here, there have been a few more machines built and running, here is a quick video of a member who built a 4x8 machine.
Thanks,
Joe
www.joescnc.com
joecnc2006 at yahoo
