Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > JGRO Router Table Design
JGRO Router Table Design For the discussion of JGRO designed router table.
Old 01-02-2010, 01:25 PM
T_Brown is on a distinguished road
Limit Switches
I just picked up some limit switches and am wondering if they will work correctly. They are Microswitch V3L 125-D8. On the side of the switch it says the following: 1/2A125VDC, 1/4A250VDC, 11A1/3HP125, 250,277VAC. The only info online that i can find is a website selling them for $143 each...?!?!? (http://ati-now.com/ATIWEB_WEB/UK/det...ITCH&P7=231684) this can't be right. I only paid $1 each. They have a common and normally closed terminal. Thanks
Old 01-02-2010, 01:53 PM
Al_The_Man's Avatar
Must be a misprint, if you look at the qty x10 they are 6.80 each which is a bit pricey even at that.
Old 01-02-2010, 07:40 PM
ger21's Avatar
Al, isn't that $68 each when you buy 10?
Old 01-02-2010, 08:03 PM
Yeah, thats the way i read it too. It looks like Honeywell also makes the same switch with the same part number, and those ones are about $68 each. Very strange, maybe i should go buy the other 100 that they had. More importantly though, these should work huh?
Old 01-02-2010, 08:38 PM
Al_The_Man's Avatar
You may be right gerry.
But I went on line to my regular supplier and the V3L series go for around 4.50 ea.!
Honeywell & Microswitch are the same company.
Limit switches BobF General Electronics Discussion 8 06-15-2008 06:31 PM
Limit switches and homing switches AeroKam Open Source CNC Machine Designs 16 01-05-2008 07:56 AM
The relationship of limit switches to home switches. MikeAber General Electronics Discussion 4 11-04-2004 01:28 PM
Limit switches and home switches viktorcnc TurboCNC 2 08-03-2004 06:11 AM
Home switches and limit switches. ynneb General Electronics Discussion 5 04-08-2004 05:32 PM
