Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > JGRO Router Table Design
JGRO Router Table Design For the discussion of JGRO designed router table.
Old 12-17-2009, 02:55 AM
stef_d is on a distinguished road
bearing alining.
I have been reenforcing the structure of my desktop machine, and replacing all the thin aluminium bearing carriages by thicker iron ones. the idea is to get rid of as much flex as possible.
this operation has been successfull on the x axis. i widen the carriages from 10cm to 15 cm, and managed to adjust the axis such that i have very smooth rolling and not play what so ever. flex is barely measurable, even if i grab hold of the gantry and twist hard.
now to the y axis. same operation. however, i spent 2 hours yesterday trying to get rid of all play in the carriages, without any luck.
I tried adujsting the position of the bearing my measuring the hole position acurately i tried alining everything precisely. i am getting close, but not close enough. i always have 1 wheel not making contact with the rod.
Is there an easy technique to aline all this correctly ?
here is a picture of the previous version of the carriage on the x axis. it is now 1/3 wider and made of iron.
the y axis is similar. on a similar rod.
vxb bearing co oldhack Linear and Rotary Motion 3 09-05-2009 12:23 PM
Bearing help Bri4n JGRO Router Table Design 6 07-22-2009 06:26 AM
Bearing help Please rodzilla Linear and Rotary Motion 2 12-17-2007 03:05 PM
Tapered roller bearing vs. angular contact bearing boyvox Linear and Rotary Motion 12 01-25-2007 02:49 PM
Bearing in MDF Photon DIY-CNC Router Table Machines 6 05-20-2004 04:18 PM
