| JGRO Router Table Design For the discussion of JGRO designed router table. |
Hi, (and first an apologize for my bad english ) after a lot of thinking, reading and watching someone else work, i'm seriously thinking of building an JGRO like machine, mostly (if not completely) in steel, i plan of put here my preliminary plan in dxf so if someone is interested in such a machine could use it.I need help on the improvement, i've seen on much post like, supporting rails, cover the rails for keep the dust away from the bearing and any other sugestion you could make. I will post some photo as soon the building start, the basic idea and starting point is: http://www.cnczone.com/forums/showthread.php?t=73787 The plan will be in metric units as I live in Italy. Many Thanks in advance to the people who can help me in this difficult mission.
__________________ Carlo |
Found this system to drive the axis. Anyone has used it? Any suggestions? link of the description http://cncloisirs.com/Construction/E...ntVictorSendas
Here the first plane of the base structure, quotes are in mm. The structure is to be made in square tubing 20x20 mm external length. The support for the rails (1" tube) are 50x50 mm external plenty of space for adjusting. Regards
Carlo, That is an excellent looking piece of welded fabrication which should be a good strong base. Thanks for sharing the picture of your start! |
| Thanks, but the welding is not made by me, the machine is made in collaboration with a friend of mine that provide the welding abilities, my field is planning, mechanical, electric/electronic design and computing. Best Regards Carlo
| My Steel Frame Router | epineh | CNC Wood Router Project Log | 484 | 07-05-2009 09:27 PM |
| New Machine Build- My steel frame router | Spiv | DIY-CNC Router Table Machines | 18 | 06-18-2009 06:14 PM |
| New Machine Build- Steel Frame 2' x 4' Router | ksubenny | Open Source CNC Machine Designs | 10 | 08-25-2008 04:47 AM |
| Build Thread- Steel Frame CNC Wood Router | CNC Rocks | DIY-CNC Router Table Machines | 12 | 08-11-2008 11:13 AM |
| My 2nd Steel Frame Router | epineh | CNC Wood Router Project Log | 12 | 07-12-2007 02:35 AM |
