Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > JGRO Router Table Design
JGRO Router Table Design For the discussion of JGRO designed router table.
Old 11-01-2009, 08:28 AM
kasari is on a distinguished road
Too much motor?
Hello,
I'm building the JGRO machine but I'm upgrading the lead screws to 1/2 - 10.
I was thinking of useing 425 in/oz motors. Is this overkill?
Also, should I use 1/2 - 10 screws on all axis?
Thanks in advance
Kasari
Old 11-01-2009, 09:17 AM
ger21's Avatar
The motors, screws, and drives need to work as a matched set. Typically, with lower priced drives, you'll get poorer performance with larger motors and 1/2-10 acme, as they can't spin as fast as smaller motors and will actually go slower.
Going with 1/2-8 2 start will double your speeds, and 1/2-10 5 start will go even faster.
What drives do you plan on using?
Old 11-01-2009, 10:12 AM
I'm useing a Hobbycnc board.
Old 11-01-2009, 10:49 AM
ger21's Avatar
If you're talking about the HobbyCNC motors, then as I said, there's a good chance that the machine will actually be slower with 1/2-10 acme. If you go with those motors, you should change to a multi start screw.
Need Help!- Changing Fanuc AC servo driver and motor for a regular VFD and async motor Bordaco Servo Motors and Drives 4 09-08-2011 05:41 PM
use satellite dish actuator motor as a stepper motor ozni Stepper Motors and Drives 7 06-18-2010 07:55 PM
Problems with motor stalling due to motor/lead screw alignment Bimmerkc1 DIY-CNC Router Table Machines 3 01-24-2010 06:12 PM
New Machine Build- Mach3 , Config, Motor Tuning problem ( FILM OF MOTOR) MDF_Markazi Mach Software (ArtSoft software) 7 04-30-2009 02:15 AM
servos motor controled by stepper motor driver? mike10 Servo Motors and Drives 1 01-03-2005 05:05 PM
