Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > JGRO Router Table Design
JGRO Router Table Design For the discussion of JGRO designed router table.
Old 10-30-2009, 01:38 PM
T_Brown is on a distinguished road
Wow - Cool new hobby
This is quite the new hobby I have just stumbled upon, and I can’t wait to dive in. After looking at some different plans that are available, I have decided to build the JGRO. I think I understand the plans for the most part, but will see once I get into it a bit more. I feel very confident in machining the parts as I have a fairly well stocked wood shop, however the electronics are a mystery to me. I don’t really want to buy a kit off the shelf as this would teach me nothing about what I am creating. Therefore I think I am going to go with the HobbyCNC EZ Board and learn and do the soldering myself. My wife is asking me for Christmas present ideas and I would like to try and get most the necessary electronics for this build. However, I don’t fully know what I need at this point. Can someone please point me in a good direction for a list of necessary components. My thoughts thus far are: HobbyCNC EZ Board, 205 oz/in steppers…then I am lost. Also any guidance that can be given regarding lead screws would be helpful. I don’t fully graps the 3/8-10 5 start vs 10 start vs 3/8-8 etc. I don’t need .0001 in accuracy and this wont be a production type machine, what is my best bet for the absolute beginner? Thanks a lot and I look forward to learning a lot.
Old 10-30-2009, 07:29 PM
ger21's Avatar
Just my opinion, but I don't think soldering the board together is going to teach you anything you need to now. When you move on to the inevitable bigger, faster machine , the higher performance drives won't require any soldering. It's just a matter of connecting wires.
Having said that, the HobbyCNC will give you the best bang for the buck, and is a good starter board. Spend the extra $5/motor and get the bigger ones, and use a 36V power supply.
As for screws, here's the basics. Say you have two screws, both 10 threads per inch. One single start and one two start. The single start takes 10 turns to move 1 inch. But the two start screw actually has two separate threads, each 5 turns per inch. So a two start screw only needs 5 turns to move 1 inch. Stepper motors torque decreases as rpm's increase, so to get the most speed, you need to keep the motor spinning slower. That's where multi start screws come in. You want to have between 2 and 5 turns per inch. 1/2" screws are probably better than 3/8", as they'll whip less at higher speeds. Best mix of price/performance is probably 1/2-8 2 start.
Old 10-30-2009, 10:38 PM
TOTALLYRC is on a distinguished road
I with Gerry
You will have so much stuff to learn that doing the driver building is superfluous.
As a suggestion, build the machine with a ready to go driver and save the electronics projects for something that is less mission critical.
G540 and matching motors would be great if a bit pricier than the hobby CNC kit you are looking at. G540, Biggest bang for the buck in my opinion.
The real nice thing is that once the router is up and running, you will be able to do simple circuit board milling on it.
Mike
Old 10-31-2009, 09:52 AM
Gerry, thanks for the explanation on the screws. Where is the best place to pick up some 1/2-8 2 start? It also seems like my best bet is going to be to make delrin nuts? Is it difficult making the tap or is that pretty easily accomplished. i am sure there is probably a how to thread somewhere out there. I think i had seen somewhere that 5/16" rod fits very well in skate bearings, so i would need to get other bearings for the 1/2" rods. Looking at McMaster theses look to be around $8-$10 each, does this benefit outweigh the additional price?
As for the driver board, i was looking at the Gecko, but the $500 price tag for the board, 3 steppers and the PS hurts the budget. I would like to try and do this first build as economical as possible. It will be easier to justify the cost if i can at least have made something that works and shows itself as useful. I know it is inevitable that i will use the first one to build the second, i would like to try and do the first one on a tight budget though.
That being said, if i get the HobbyCNC board, i also need to get the transformer, a 36V PS and the steppers and thats it for the electronics right?
Thanks a lot guys, you have already taught me something.
Old 10-31-2009, 10:05 AM
ger21's Avatar
You can get the screws from McMaster Carr, MSC, or Roton. I highly recommend going with the Dumpster CNC nuts. money well spent. I had intended on making my own nuts, and after the first one was done, I ordered the Dumpster nuts for the rest. www.dumpstercnc.com
Here's how I mounted my screws in cheap roller blade bearings.
http://www.cnczone.com/forums/showthread.php?t=86180
If you buy the package from HobbyCNC, all you need is the transformer. The other parts to build the power supply are included in the kit. The HobbyCNC will be fine for a first machine.
Old 10-31-2009, 11:41 AM
radcliffe is on a distinguished road
I agree with Gerry, If you do go with the Hobbycnc package I recommend the Pro with 4 305 steppers. This way when you build your second and larger router you will already have the fourth axis and stepper to run dual axis on the x axis.
You can buy the transformer from MJPA, INC. After it has been bridge and filter you will have 33-34 volts at 10 amps.
http://www.mpja.com/category/Transfo...ER_7846_TR.asp
I brought the Pro Package with four 305 steppers and had no problem in the assembly, just follow the great instruction supplied.
Harold
Old 10-31-2009, 10:56 PM
Thanks for the responses. I think i am going to go with the HobbyCNC Pro Board with 3 305 steppers. The only additional electrical compnenet i need then is the transformer, correct? I should be fine to just mount it all in an old computer tower right?
Perhaps you can shed a little light on computer software now. I have quite a bit of knowledge of AutoCad, but only 2D. Is there a program with an easy learning curve to move to 3D obects? I am currently planning on just cutting out parts and doing some sign carving but i dont want to limit myself.
Once i have created my part in AutoCad or said other program, then i need to send it to a program to convert it to g-code right? I have heard some good things about LinuxCNC, do you have any experience with this? Once i have it covnerted to g-code than it goes to a CAM software which talks to the router and starts the cutting. Thoughts on this program?
I dont want to break the bank on software at this point, but also don't want to be continually fighting with the program.
Last question (of this post, i am sure there will be many many more) is there some sort of assembly manual created for the JGRO plans? Something that talks about alignment and order of assembly and such?
Thanks guys!
Old 11-01-2009, 12:11 AM
MrWild is on a distinguished road
There are quite a few hidden costs that jump up also. Many go with Mach 2 or Mach 3 as the interface program so the computer controls the motors ($160). Linux EMC2 is free and has a near turn key set up for stepper control. It also has a near plug and play for the Gecko G540. The G540 does away with wiring confusion and lets you concentrate on learning CAD/CAM which will be a challenge in itself. You can spend a lot to a little for CAD/CAM. A lot is over $10k to a little of free. The money you save with EMC2 would allow more funds elsewhere.
Old 11-01-2009, 06:07 AM
ger21's Avatar
The CAM software is what creates the g-code. Control software is what runs the machine.
I create my g-code in AutoCAD with a macro I wrote. Works with 2002 and newer versions. Link in the last post. http://cnczone.com/forums/showthread.php?t=8226
Basically, you just draw where you want the tool to go. In a lot of cases, you can just offset the part outline by the tool's radius.Feel free to ask for any help in that thread.
I think you'll find that most parts do not require 3D modeling. Just a simple 2D drawing.
There are many inexpensive CAM packages out there. SheetCAM and Vectric's Cut2D are probably the most popular.
Sign carving is a vague description, but you might also want to look at V-Carve Pro It's a bit more money, though.
All these programs can use .dxf files from AutoCAD, and will automate a lot of the process of creating toolpaths from your drawings.
By far the most popular control software is Mach3, but if you don't mind Linux, then EMC is pretty poular, and it's free.
Old 11-02-2009, 11:30 AM
Can someone please enlighten me on this?
10-24 UNC (Down Arrow) 2B 1.500
The down arrow with top didn't copy. I think it means tap a 10-24 thread down 1.5 inches. If this is the case, what does the 2B stand for? Thanks
  #11   Ban this user!
Old 11-03-2009, 09:46 AM
iwantone is on a distinguished road
It is the class of the thread , this link should help explain:
http://www.newmantools.com/taps/taptech.htm
  #12   Ban this user!
Old 11-03-2009, 05:57 PM
TommieK is on a distinguished road
Cool new hobby
First, I would like to welcome you to the community. Second, some of these guys and gals on here are way smart. As far as the tap type and thread class goes, whatever tap or die that you can purchase at your local hardware store is going to be just fine for anything on the JGRO with the exception perhaps of any ACME thread you might decide to go with on your lead screws. Some of the members have made their own (Glidergider is one and he shows pictures of it). I got my 1/2inch 8-2 lead screw material and backlash nuts through Dumpster. I did try 1/4-20 stainless for leadscrew first because I didn't know any better and because I thought I did, but the 8-2 makes you feel like your running an honest to god real CNC. So much smoother and faster. Good luck with your build, oh and post pictures. Tom
p cool Delw Haas Mills 10 07-17-2009 05:08 PM
Oh.. this is cool... murphy625 CNCzone Club House 5 06-14-2005 07:39 PM
want to see something very cool Stevie General Metal Working Machines 17 02-10-2005 06:22 AM
cool vid nervis1 CNCzone Club House 4 02-09-2005 10:28 PM
How cool is this ! CNCadmin Product Announcements & Manufacturer News 8 04-27-2003 08:34 PM
