Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > JGRO Router Table Design
JGRO Router Table Design For the discussion of JGRO designed router table.
Old 09-15-2009, 10:21 AM
autophile is on a distinguished road
Question Putting together Base Assembly (assy02)
Hi all,
So I've built my Base Support Structure (dtl05) and Bed Assembly (assy04). I'm about to cut the side supports (dtl01 and dtl02). My question is, what holds the side supports to the base and bed? If I glue them all together, I won't be able to install (or maintain) all the fiddly little bits on the inside, like the bearings, coupler, lock washer, etc. Do I just glue the supports to the base and leave the bed to be removable?
Thanks!
--Rob
Old 09-15-2009, 07:59 PM
Bri4n's Avatar
Bri4n is on a distinguished road
I used bolts to hold the base to the supports and plan on using screws to hold the bed down.
Old 09-16-2009, 09:47 AM
Thumbs up
Good idea -- I will certainly do that!
Need Help!- Putting my X3 together, will need a lot of help Ed from NY Syil Products 315 11-05-2009 03:00 AM
Putting a label on a part Andreas0815 Solidworks 2 09-26-2007 08:56 AM
Putting a flat on drill rod Fred Ming General Metalwork Discussion 9 12-06-2006 09:54 PM
Putting It all together whitney General Electronics Discussion 6 09-29-2006 06:24 PM
putting a dollar value on your buisness imwllc General Metal Working Machines 3 05-23-2006 06:11 PM
