Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > JGRO Router Table Design
JGRO Router Table Design For the discussion of JGRO designed router table.
Old 07-11-2009, 04:27 AM
Bri4n's Avatar
Bri4n is on a distinguished road
Bearing help
I've been lurking here for a while and am just getting ready to start my first JGRO router. I am on a tight budget and already have some parts lying around I'd like to use. I noticed in the plans it calls for 8x22 mm bearings, I have some 12x28 bearings and was wondering if it would be okay to use these without changing any of the other dimensions? I would like to stay as close to the plans as possible being how this will be my first build.
Old 07-11-2009, 05:31 AM
ger21's Avatar
Not positive, but I think you'd have to change quite a few things to use larger bearings, since the location of the angle they mount to would be further offset from the pipe. You may be able to just change the bearing location and make it work, but I don't know, as I've never looked at the plans.
Old 07-11-2009, 02:19 PM
Bri4n's Avatar
I was afraid of that.
Old 07-11-2009, 03:28 PM
ger21's Avatar
You can get cheap bearings from www.vxb.com The cost of new bearings will be minimal when compared to the overall cost of a running machine.
Old 07-16-2009, 12:02 AM
mlabruyere's Avatar
mlabruyere is on a distinguished road
I got mine on eBay dirt cheap.
Old 07-21-2009, 10:34 PM
Wrench900 is on a distinguished road
ebay's is the place to look for sure. Picked up 30 of them for just over 8 bucks.
Old 07-22-2009, 06:26 AM
Bri4n's Avatar
I actually picked up some parts from another member and bearings were included. Thanks
How to cut a bearing block ? ringram2077 General Metalwork Discussion 14 04-02-2008 09:49 PM
Bearing help Please rodzilla Linear and Rotary Motion 2 12-17-2007 03:05 PM
Tapered roller bearing vs. angular contact bearing boyvox Linear and Rotary Motion 12 01-25-2007 02:49 PM
Bearing sala84 JGRO Router Table Design 7 11-03-2006 09:42 AM
Bearing in MDF Photon DIY-CNC Router Table Machines 6 05-20-2004 04:18 PM
