Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > JGRO Router Table Design
JGRO Router Table Design For the discussion of JGRO designed router table.
Old 06-24-2009, 11:04 PM
martinrobt is on a distinguished road
Question Aluminum Tubing Gantry
Has anyone ever made a gantry out of square aluminum tubing? I'm finishing up plans for a JGRO based machine and instead of MDF, I was wondering if 1/8" thick square aluminum tubing would be a better (lighter) choice. I'm accomplished at brazing so the joinery wouldn't be a problem. I just don't know if it would handle the stress. Would it be stiff enough.
Specs of machine.
Modified JGRO design
24" x 24" cutting area
200 oz steppers
1/2 10 ACME lead screws with Acetal nuts
Robert
Old 06-25-2009, 07:42 AM
skippy is on a distinguished road
In order to get some answers it might be a good idea to tell everyone the size of the ali tube rather just the wall thickness.
Brazing aluminium tubing? huh?
Old 06-25-2009, 04:50 PM
I was thinking of 1.25" square tubing.
And yes, brazing. Although it can be a little tricky at first, brazing aluminum is actually fairly easy. One key to doing it well is not only use flux on the aluminum, but to preheat the brazing rod and dip it in flux as well.
Robert
Old 06-25-2009, 08:31 PM
martinw is on a distinguished road
Dear Robert,,
If you could post more details of the design that you are considering, it would be very helpful to everybody.
Best wishes,
Martin
Old 06-25-2009, 09:56 PM
Don954 is on a distinguished road
So i came across a similar machine to the JGRO on another www, and was about to sit down a draw up my own vesion using a steel frame, replacable bed, and aluminum tubing gantry.... and just before starting today i decided to check if anyone had done it before lol, not only did i find the JGRO drawings completely done in solidworks! i also find someone else with aluminum gantry inspirations, whooda thunk it.. this interweb is amazing.
I plan on aimin for a 3'x4' size machine, with similar motor strength, and similar acme screw, with a welded steel tube frame base which MDF bed with bolt into (eventually like to get aluminum honeycomb bed and make vaccum table). Using similar size aluminum tubing for the gantry BUT i will likely make it two tubes up and across and down with trusses inbetween for ridigity. I find it extremely hard to beleive this will have stress issues but i will have a TIG welder.. (don't know the strength of brazed alum joinery). I beleive the week spots in my plan will be in the linear ball bearing slides.. and an ability to cut depth in the Zaxis. Routers usually only have about 2" of bit to plunge with and i want to be able to do some foam surfacing of greater depth... i may resort to making my own lower speed servo driven spindle that i can mount an end mill in but i fear this will be too pricey for my pocket book.
Anywho, keep in touch Robert, i'm interested to see how our parallel projects progress.
Cheers
Don
Old 06-25-2009, 10:35 PM
The base of the machine will be all JGRO, made from MDF, except for the size. It's the gantry I'm thinking about using aluminum tubing on. From the sound of it, it sounds just about the same as Don described.
Although I've never had a problem with a grazed joint failing, I guess there's a first time for everything. I just don't have a welder.
Don, thanks for the encouragement. Good luck to you. I'll check back in to see how you're doing.
Robert
Old 06-26-2009, 11:47 AM
harryn is on a distinguished road
I think you will be much more satisfied with 1/4 in thick Al sq tube. It is really handy to have Al thick enough that it can be tapped, and the difference in stiffness is dramatic.
Supporting RanaTeckk.com and their Dashboard for MS Project promo code WRLNT-2
HELP! Best way to cut ALUMINUM square tubing in thin slices w/o kickback? toolmetal General Metal Working Machines 37 02-03-2009 07:10 PM
PEX hose/ Tubing? fretsman Work Fixtures and Hold-Down Solutions 2 06-19-2008 03:58 PM
Brush finishing aluminum tubing in quantity mxtras Mass finishing equipment/media/stratigies 17 01-02-2008 10:37 PM
Game plan for assembling aluminum gantry WoodSnarfer DIY-CNC Router Table Machines 2 02-28-2007 07:38 AM
Quote for Simple Aluminum Tubing Part BrianTx21 Employment Opportunity 9 02-04-2006 10:49 AM
