Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > JGRO Router Table Design
JGRO Router Table Design For the discussion of JGRO designed router table.
Old 06-12-2009, 03:06 PM
daffelglass is on a distinguished road
Code Breaker Needed!
So, I'm new to the world of CNC and of most woodworking projects and I need help understanding the designs. I'm currently reading through the JGRO designs, and I was wondering if someone could explain the notation used to me. If someone could decipher the attached photo, it would be most appreciated.
Many thanks
Old 06-12-2009, 03:17 PM
Eurisko is on a distinguished road
Use a #7 drill (.201 diameter) to drill a through hole. Then tap the hole .507 deep with a 1/4-20 tap.
There are 4 of these tapped holes, the print should show you where they go!
Diplomacy is the art of saying "Nice doggie" until you can find a rock. - Will Rogers
Old 06-12-2009, 03:22 PM
Thank you! It makes sense now! You've been a great help.
Many thanks
(btw, your sig should read 'ipso' not 'ipsos')
Old 06-12-2009, 03:23 PM
ooh, just checked, ipsos is right. my bad
Old 06-14-2009, 08:53 AM
TommieK is on a distinguished road
Code Breaker Needed
A word or two of advice. Before you drill and tap all those holes in the MDF yoy might consider doing a dry fit to see how everything goes together and then maybe consider a different way to attach pieces. MDF has a curious tendency to split at very inopportune (SP?) times and can ruin several hours worth of work in a moments disaster. If you do decide to tap the MDF anyway; Step 1 mark. Step 2 drill. Step 3 tap. Step 4 soak with superglue. Step 5 allow time to dry. Step 6 Retap. Maybe others can add suppliments. Tom
Breaker size? Delw Haas Mills 3 06-05-2009 07:13 AM
TL-1 breaker size hercules Haas Lathes 12 04-11-2009 12:26 PM
VF-2ss coolant breaker extanker59 Haas Mills 3 10-22-2008 10:18 AM
Circuit breaker trips out? Splint General Electronics Discussion 3 12-11-2005 09:24 AM
Bit breaker CNCadmin Mach Mill 6 11-22-2005 06:33 AM
