Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > JGRO Router Table Design
JGRO Router Table Design For the discussion of JGRO designed router table.
Old 05-03-2009, 11:55 PM
mlabruyere's Avatar
mlabruyere is on a distinguished road
Another JGRO machine......:)
Hi everyone,
My first post.....woot!
I started the build last weekend using the "latest" plans on the JGRO thread.
I'll be using an Easy-CNC 3axis controler with a power relay for the router.
I'm going to get the steppers from Anaheimautomation to pickup 3 24Y504S-LW8 432oz/in.
For starters I am going with 3/8 - 16 Allthread with HDPE anti-backlash nuts.
This will be my first table CNC. I currently have a "PhlatPrinter" for cutting foam and thin ply.
One thing I have figured out while building this machine is my wood working skills have gone to heck.....my wood shop coach would be really unhappy with me....it's ugly.....really ugly.....
Matthew
Old 05-04-2009, 07:47 PM
mlabruyere's Avatar
I'll get some photo's in a few days....like I said it's not pretty.
I am planning to use metal dowel nuts where ever I can. I hate to tap into the MDF it just doesn't hold very well....
Old 05-05-2009, 12:39 AM
tbenefi33 is on a distinguished road
Hi welcome to the forum.
Old 05-05-2009, 01:41 PM
mlabruyere's Avatar
Thanks!
Old 05-08-2009, 06:37 PM
mlabruyere's Avatar
Another note:
I'm using Mach3 (I purchased the full version last year) to run the G-Code but I need a good program to generate G-Code.
Do you all know of anything, other than PhlatCode, that will create G-Code within Sketchup? I've gotten used to using it but I have ACAD as well so I can create DXF or DWG if needed and get G-Code from there.
Old 05-13-2009, 03:21 AM
mlabruyere's Avatar
Just got the bearings in the mail!
I decided to get angleiron rather than aluminim since my local HW store just has 1.5x1.4x.125 aluminium. The angleiron is 1.25x1.25x.125 whicj is what we need.
I did find that the Z-Axis bearing block slots are too close together.....drat.....I'm cuting them again....
Old 05-13-2009, 10:55 PM
mlabruyere's Avatar
Just ordered the Steppers:
http://www.kelinginc.net/KL23H276-30-8A.pdf
Great deal....I hope 282OZ/IN will be enough!
Old 05-15-2009, 11:25 PM
mlabruyere's Avatar
I got the HDPE in today and completed all of the adjustment blocks. This was much easier than trying to drill and tap MDF....
I also completed the bearings for the Z-Axis tonight.
Old 05-15-2009, 11:28 PM
mlabruyere's Avatar
Got the UHMW in the mail today and completed all of teh adjustment blocks. This was much butter than trying to drill and tap MDF.
I also completed the Z-Axis bearings. That angle iron is tough to tap but man you can really torque the bolts in it!
Old 05-17-2009, 01:50 AM
mlabruyere's Avatar
Am I going to have issues with the 3/8-16 All Thread and the steppers I have? Lost steps.....slowness....?
  #11   Ban this user!
Old 05-17-2009, 07:29 PM
mlabruyere's Avatar
Here are some pictures.
Shown are the Z Gantry bearings, all of the UHMW bearing blocks (and the system I used on the drill press to keep all of them centered), The new steppers all wired (Bipolar Series), and the crummy Gantry back plate I cut.....oh well...it's not pretty but it should work.
I should have the gantry completed this week.
Name:	DSCN5677 (Small).JPG‎
ID:	81500   Click image for larger version
Name:	DSCN5685 (Small).JPG‎
ID:	81501   Click image for larger version
Name:	DSCN5686 (Small).JPG‎
ID:	81502   Click image for larger version
Name:	DSCN5687 (Small).JPG‎
Name:	DSCN5688 (Small).JPG‎
  #12   Ban this user!
Old 05-26-2009, 10:50 AM
mlabruyere's Avatar
I finished the Z-Axis and have nearly completed the Y-Axis. I figure at the pace I am able to work I am looking at about 3 months to first cut.....
New Machine Build- First Machine- Northboys yet another JGRO variation Northboy CNC Wood Router Project Log 58 02-25-2010 03:24 PM
DeadTom's JGRO machine DeadTom JGRO Router Table Design 19 11-01-2009 02:50 AM
First Machine -JGRO wallyh JGRO Router Table Design 39 03-18-2007 06:46 PM
JGRO Design OK for First Machine wallyh JGRO Router Table Design 7 07-15-2006 08:43 PM
jgro machine - drill rod for rails? creative_mind JGRO Router Table Design 7 07-14-2005 09:12 PM
