Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > JGRO Router Table Design
JGRO Router Table Design For the discussion of JGRO designed router table.
Old 02-17-2009, 09:03 AM
stabbs is on a distinguished road
JGRO build, mostly steel
so, after about six months here is my JGRO CNC finally up and running. I plan to use it to cut out plastic parts for models. I am still working out the software end but I will soon try to post some videos.
The framework is mostly steel, built from three old bed frames. I was able to get one from my parents basement, one from my mother-in-law's basement, and one I found on the side of the road. I was also able to get the plywood from my grandfather, so the overall frame material cost was $0.00.
I probably spent about $100 to $125 on hardware; nuts & bolts, couplers, delrin for the anti-backlash nuts, acme rods, etc.
I used my ryobi router- I simply removed the handles and outer housing which reduced the weight by almost half.
I got a 4 axis controller package from Xylotex. Jeff has been great over email & the package is top notch. I was considering building a board, but I have a knack for ruining things, & I didn't want to chance it on an expensive board kit. But the package runs perfect- smooth and easy to install.
Old 02-17-2009, 09:06 AM
this is an early shot of the steel framework. It is all welded together. I enjoy working with steel, but it was very difficult to get everything square. I had to rebuild the gantry 4 times.
Old 02-17-2009, 09:07 AM
this is a shot right before I disassembled everything for painting and final assembly.
Old 02-17-2009, 09:09 AM
Table top torsion box
I built a torsion box to lay on top of my table, as the tabletop was bowed. This helped to square everything down the road.
Old 02-17-2009, 09:10 AM
Base
Old 02-17-2009, 09:12 AM
Gantry
Old 02-17-2009, 09:14 AM
Anti-Backlash Nuts & Hardware
The anti-backlash nuts are delrin per JGRO's blueprints. The tap for the 1/2" 10 screws are very expensive, but I found in another thread somebody made one from a piece of thread. I used my grinder and the drill press to make this one. It isn't pretty, but it did the job.
Old 02-17-2009, 09:15 AM
Gantry with Anti-Backlash Nuts & Screw
Old 02-17-2009, 09:16 AM
x- axis
Old 02-17-2009, 09:18 AM
Close up of the Motor on the X-Axis
  #11   Ban this user!
Old 02-17-2009, 09:19 AM
Z- Axis
  #12   Ban this user!
Old 02-17-2009, 09:26 AM
Software
I am using solidcam and Mach 3 to run the CNC. I tried cutting my first part last night and it was a disaster. When I figure out how to run it, Ill post some videos from youtube.
09-07 jgro build CNC-Dad JGRO Router Table Design 3 02-22-2012 09:23 PM
mostly steel JGRO drafterman JGRO Router Table Design 4 11-21-2007 07:29 AM
My JGRO build Sieg JGRO Router Table Design 46 10-31-2007 08:36 AM
going to build the jgro clammy23 DIY-CNC Router Table Machines 0 01-04-2007 05:44 AM
Yet another jgro build bnoble JGRO Router Table Design 2 11-16-2005 09:51 PM
