Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > JGRO Router Table Design
JGRO Router Table Design For the discussion of JGRO designed router table.
Old 02-12-2009, 03:20 PM
Gyvven is on a distinguished road
Smile 24"X36" CUTTING BED
I've decided to make a JGRO but I wanted a larger bed. Instead of the 15x30 I've seen mentioned, I wanted a 24x36. So, I began stretching all the pertinent parts by 6" or 9" and planning how they lay out on a 49"x97" sheet of MDF along with recommended first few cuts and accounting for a 3/32" kerf.
Here's what I came up with if anyone is interested. It's still a bit sloppy but I'm going to start cutting and labeling parts this weekend. The sheets are all either 1" or 3/4"=1'-0" and fit on 8.5x11.
-75 MDF is the 3/4" sheet
-5 MDF is 1/2" (you may have to put 2 of the supports short pieces on one end.)
-Dimensions is a reference sheet just for the 3/4"
-Base and bed support layout. (All of the cross pieces are going to be dado'd to slide together for a firmer sturdier fit.)
I was also considering a vacuum hold down system. Just drill a bunch of holes in the bed support framing and top, add a 1/4" mdf bottom and a vacuum connection in the end. Has anyone done/tried that?
Thanks,
Gyv
Old 02-12-2009, 04:13 PM
Sorry, I just realized I forgot to double the ends. I'll rework it. Boy that's tight.
Try this.
Need A Quote- Wire for foam Cutting "EdgeSweets" machine singerdon49 Employment Opportunity 0 12-29-2008 08:12 AM
Need help cutting 8.5"dia x 1.5" round stock in half NN2 General Metalwork Discussion 10 12-04-2008 08:44 AM
Why is the cutting bit taking the "scenic tour"? BrassBuilder Dolphin CADCAM 5 03-17-2008 09:58 PM
Vertical system "jerks" and "bangs"?? REVCAM_Bob Servo Motors and Drives 5 06-12-2006 09:09 AM
Cutting "out" items from a sheet MrBean DIY-CNC Router Table Machines 12 01-03-2005 11:55 PM
