Results 1 to 3 of 3
Thread: adjustment block material: MDF, delrin, HDPE, ?
    Jul 2007
    The JGRO plans specify MDF for the adjustment blocks. However, I've been reading build threads and have noticed that some people are using (presumably) delrin for the blocks. I've seen others mention HDPE.
    What's the consensus on this? I can imagine these take quite a bit of stress, so I'm leaning towards the plastic. If this makes sense, which is better choice between delrin and HDPE?
    thanks!
    Dec 2004
    Barbados
    Personally which ever is cheaper should be fine. Although I have never changed my MDF blocks the plastic version will be a lot more durable.
    Jason
    May 2008
    [Delrin is a better choice because it it more durable and not as sticky to work with. Both will work as will MFD but I feel delrin is nicer to work with and will last the life of the machine and then some. On the x axis don't use HDPE. it doesn't seem to have the strength or rigidty required. I tried it and was not happy with the results. Delrin worked great and if your going to use plastic thats the one to use..Ron BB
    thanks![/QUOTE]
  1. Delrin or HDPE, which did you use?
    By Glidergider in forum DIY CNC Router Table Machines
    Last Post: 07-22-2010, 09:14 PM
  2. UHMW vs Delrin vs HDPE rail slides
    By Rance in forum DIY CNC Router Table Machines
    Last Post: 01-03-2009, 04:16 PM
  3. How to cut Block of Fiberglass material ?
    By Calico in forum CNC Tooling
    Last Post: 11-06-2008, 06:55 AM
  4. Adjustment block ?
    By deleteallusers in forum DIY CNC Router Table Machines
    Last Post: 02-16-2007, 01:50 PM
  5. Delrin, HDPE or similar in Aus?
    By Agro in forum Australia, New Zealand Club house
    Last Post: 06-09-2006, 06:47 PM
