Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > JGRO Router Table Design
JGRO Router Table Design For the discussion of JGRO designed router table.
Old 08-04-2008, 01:12 PM
richviper is on a distinguished road
Z Axis Bearing setup help!!!
How did everyone setup the Z Axis bearing arrangement so that when the 1/4- 20 rod spins it does not drop the rod out of the bottom? The drawings show a nut at the bottom and then a washer, the bearing, spacer and another nut. What retains the rod on the upper side??? I am missing something....
Does anyone have a picture of their setup?????
Thanks a mint!
Richviper
Worked all weekend on the CNC and only have to mount the Gantry to the Y-Axis. Had a few issues but seem to have everyhting solved except the Z-Axis issue. Did find that the gas pipes are not really true and had to put them on a lathe to ensure all bearings ride along the full length of the pipe. Also the aluminum angles used for the bearings must have the holes drilled very precisely. Other than that is is a very nice design and fun to build. I can't wait until my steppers arrive tomorrow!!!!
Old 08-04-2008, 08:26 PM
Ok figured it out. I am adding 2 bearings to the Z so it is the same as the X axis.
I am also changing the Y-Axis to half inch with a Flanged bearing assembly.
Need Help!- Mach3 A axis (4th axis) setup? cadcamslawek Mach Software (ArtSoft software) 10 01-17-2012 08:23 PM
x axis bearing truck blackbeard52 Open Source CNC Machine Designs 10 01-13-2008 09:01 AM
X-Y-Z Axis Bearing Support - Dimensions? joecomunale Joes CNC Model 2006 20 05-17-2007 05:49 PM
new bearing design for x-axis myinisjap Linear and Rotary Motion 6 02-02-2007 06:55 AM
What is 4th or 5th axis bearing type ? bigg Mechanical Calculations/Engineering Design 2 10-03-2006 01:54 PM
