Hello, i am totaly new one in this cnc diy thing. I want to make one cnc machine for bcb milling and i want to ask is there some way to run cnc machine with pcad? (Sory about my bad english, i am latvian)
No you cannot use P-CAD to run a machine. The machine is run by a program that generates step and direction signals like mach3 or turbocnc. P-CAD will allow you to design a circuit and possibly convert the traces to dxf which then can be loaded into a program to generate Gcode or directly into Mach3 for gcode conversion.
Diptrace is a circuit design program that allows conversion to dxf.
