Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > JGRO Router Table Design
JGRO Router Table Design For the discussion of JGRO designed router table.
Old 05-20-2008, 07:09 AM
Rickv100 is on a distinguished road
cutting bearing support channel
I am building a JGRO as my first router and have learned alot from all the other threads, I am facing issues routing the channels for the linear bearings.
What have others used to cut the channels? For dtl34 and dtl40 are the measurements the centerlines of the channel or the bottom edge of the channel?
Regarding polishing the gas pipes if you turn inside out a belt sander belt you can polish a pipe that way. That is how boat builders sand masts.
Rick
Old 05-26-2008, 08:32 PM
Glidergider is on a distinguished road
Rick,
Good picture of the belt sanding mast method. Excellent.
Regarding the channels for the details 34 and 40, I used my cheap table saw. However, if I did it again, I should have used my router and cheap router table. If you don't have a router, well, you will need one soon. I favor the Hitachi, variable speed router. Costs about $120 at your HD or Lowes.
Good luck on your build. I really enjoyed my JGRO. I recently looked at my Mach3 odometer, and I discovered that I cut about 3 miles worth of wood this past year.
Lots of fun.
Dave
X-Y-Z Axis Bearing Support - Dimensions? joecomunale Joes CNC Model 2006 20 05-17-2007 05:49 PM
Tapered roller bearing vs. angular contact bearing boyvox Linear and Rotary Motion 12 01-25-2007 02:49 PM
Newbie leadscrew support/bearing question lukaslouw DIY-CNC Router Table Machines 0 09-23-2005 10:03 AM
IRC channel for EMC Dan Falck LinuxCNC (formerly EMC2) 0 12-18-2004 11:03 AM
Two steppers from one channel? m1911bldr General Electronics Discussion 1 03-29-2004 08:30 PM
